Bluetooth Issue with Android 9
  1. axelgrease15 Cupcake Dec 30, 2018
    axelgrease15, Dec 30, 2018 :
    Still having issues with Bluetooth Fitbit Versa, after trying all options in this thread. Just a fyi for those who read this in the future who are having problems with their Fitbit. I will submit a bug report, hopefully OP send out a bug fix soon
  2. axelgrease15 Cupcake Dec 30, 2018
    Found solution by pairing versa first through OnePlus bluetooth, then unpair, then pair again this time through Fitbit app
    Akhshay Srinivasan likes this.
  3. Akhshay Srinivasan Nougat Dec 31, 2018
    Akhshay Srinivasan, Dec 31, 2018 :
    Nice :) Have fun.
  4. joe1826 Cupcake Jan 16, 2019
    joe1826, Jan 16, 2019 :
    I found a solution that may work for some people. I was having trouble with BT staying connected. After trying everything here I just went into BT Dev tools and tried each setting one by one until my BT worked. The culprit was the Disable Absolute Volume. Set that to active and things started working again. Without that active your phone media Volume controls will be independent of the device Volume control which means you will have to turn the volume up on your phone and device in order to control it. Small price to pay to get my BT working again.
  5. H1529680790846 Cupcake Feb 1, 2019
    H1529680790846, Feb 1, 2019 :
    Hey u got the solution for this? Am also facing this issue, any way out?
  6. Chinaroad Gingerbread Feb 1, 2019
    Chinaroad, Feb 1, 2019 :
    it turned out i had shitty bluetooth hedset, with another bluetooth ones (senheisser hd1 free) i dont have that problem, the aptx is helping alot
  7. H1529680790846 Cupcake Feb 1, 2019
    I have a great branded one. gonoise brand. Still got the issue. Culd u plz help me out..spcly wid pubg am.facing this lag. Need a solution plz
  8. H1529680790846 Cupcake Feb 1, 2019
    And what is this aptx?
  9. G_Erjan_Vreemann_lhQt Cupcake Jun 19, 2019
    G_Erjan_Vreemann_lhQt, Jun 19, 2019 :
    Hi,
    I have updateted my OP3 to Android 9 since then i have problems with my bluetooth, is there a solution found in the meantime?
  10. G_Dustin_Gosselin_JMIF Cupcake Jun 22, 2019
    G_Dustin_Gosselin_JMIF, Jun 22, 2019 :
    After an Android update, you are facing Bluetooth issue with your Garmin smartwatch and as you mentioned it is not showing notifications also. Now, have a look at your question, the answer lies in itself. All this started after you updated the android version. So you need to check with the update first if it was installed peoperly. Also, there may be a connection error with your device , so you shuld check this guide to get all your Bluetooth related issues fixed. For further assistance, you can contact Garmin Experts and get your issue resolved in no time.
  11. mtattie Cupcake Jul 17, 2019
    mtattie, Jul 17, 2019 :
    My Garmin 520 is not connecting properly after this update on my op3t.
    I've tried all the things above but still no joy.
    It shows up on 520 but will not pair fully.
    I'm ready to kill my 3t
  12. mtattie Cupcake Jul 17, 2019
    Turns out uninstalling Garmin connect then connecting it from scratch has solved the problem
  13. D1540982405627 Cupcake Jul 18, 2019
