Bluetooth issue via OnePlus 8T
  1. Gamingtime1121
    Honeycomb Apr 5, 2021
    Gamingtime1121 , via OnePlus 8T , Apr 5, 2021 :
    I have issues with Oneplus 8t bluetooth while connecting with my car. Sometimes it takes too much time to sync with car or it shows random music track on the screen which is not being played. Furthermore at times it shows disconnected on the screen even though it is still synced with cars bluetooth. I already chose as forget and paired again plus i also reset wifi, mobile and bluetooth from the settings but nothing worked. Other phones don't have this issue with my car when syncing.
  2. hbk1402
    Jelly Bean Apr 5, 2021
  3. #4
  4. #5
  5. psygarden
    OnePlus TV Product Ninja 2021 Apr 5, 2021
  6. Gamingtime1121
  7. Gamingtime1121
  8. Gamingtime1121
    psygarden likes this.
  9. hbk1402
    hbk1402 , Apr 5, 2021 :
    Try resetting your bluetooth settings,
    Open settings -> System -> Reset options -> Reset Wifi, mobile & Bluetooth and confirm
    Note this will reset also your wifi, bluetooth paired devices but you can re-connect/repair them again anyway.
    If still the issue persists then wait for the query that you have submitted under feedbacks
  10. Gamingtime1121
    Already reset these settings and paired back but it doesn't solve the issue.
    hbk1402 likes this.
  11. #13
  12. vikarshaikh18
  13. hbk1402
  14. #16
  15. R1603955279095
    Eclair Apr 5, 2021
  16. warrior143
    Ice Cream Sandwich Apr 6, 2021
  17. kamal.kv
    Honeycomb Apr 7, 2021
    kamal.kv , via OnePlus Community App , Apr 7, 2021 :
    Usually it's tries to connect multiple devices if those are enabled, remove all synched devices from phone and connect to car. See if this works else better reset the device.
