Bluetooth Issue
  1. G_Akshat_Bindal_ULmn Cupcake Aug 28, 2017
  2. ramneeksingal Cupcake Aug 28, 2017
  3. rodrieste Eclair Aug 28, 2017
  4. KRZYSZTOF_BEDZISZ_BEDA Eclair Aug 30, 2017
    KRZYSZTOF_BEDZISZ_BEDA, Aug 30, 2017 :
    me too... this annoying - ONEPLUS any help for that issue?
  5. vsmclub Froyo Aug 30, 2017
    vsmclub, Aug 30, 2017 :
    How to fix OnePlus 5 Bluetooth issues:
    Power on your OnePlus 5
    Open the app icon
    Tap on settings
    Select Application Manager
    You can display all tabs by swiping in either direction
    Tap on Bluetooth
    Select to stop it forcefully
    Next go ahead and clear the cache
    Tap clear the Bluetooth data
    Tap on Ok
    Now restart your OnePlus 5
    If you’re not able to fix the OnePlus 5 Bluetooth problems with the instructions from above, we recommend that you either put the phone into recovery mode or wipe cache partition.
    This should help you fix your bluetooth issue.
  6. KRZYSZTOF_BEDZISZ_BEDA Eclair Aug 31, 2017
    KRZYSZTOF_BEDZISZ_BEDA, Aug 31, 2017 :
    I made both steps, independently of each other. It only changed so much that it detects all the devices, shows them but does not want to connect them. There is also no confirmation of pin / passkey
  7. G_Manan_Chaudhary_tDoz Cupcake Aug 31, 2017
  8. KRZYSZTOF_BEDZISZ_BEDA Eclair Aug 31, 2017
  9. RoyBen Cupcake Sep 7, 2017
    RoyBen, Sep 7, 2017 :
    Hi, I have tried following your guide, but I fail at the second instruction 'Open the app icon'. What 'app icon'? I am unsure what you mean. Can you clarify this for me please. I am on Android 7.1.1 and OxygenOS 4.5.10. Thanks for your help. Roy
  10. F_Pratik_Patel_gRih Cupcake Sep 7, 2017
    F_Pratik_Patel_gRih, Sep 7, 2017 :
    I connected my oneplus 5's Bluetooth in my WV POLO & SUZUKI BALENO , and it got paired and connected at first place but music is not playing , in advanced settings of Bluetooth "phones media" was uncticked .
    I tried to mark all options but not responding .
  11. felipemendes Jelly Bean Sep 7, 2017
    felipemendes, Sep 7, 2017 :
    Some cars (like my Nissan Pathfinder) will only connect to phone, not media. This is nothing to do with the phone.
    On the other hand, something that helped me with bad connections was to clear BT share data. Settings>Apps>...>Show System Apps>Bluetooth Share>Force Stop/Clear Data.
    After that, remove the pairing both on phone and car, and connect again. Worked on my wife's Volvo XC60 and OP5.
    LOgden likes this.
  12. mywolf2 Ice Cream Sandwich Sep 7, 2017
    mywolf2, Sep 7, 2017 :
    Lots older bluetooth dont work with new blue tooth same happens with samsung s8
  13. LOgden Cupcake Oct 6, 2017
    LOgden, Oct 6, 2017 :
    This worked for me!
  14. LOgden Cupcake Oct 6, 2017
  15. simonsmidt Cupcake Jan 15, 2018
    simonsmidt, Jan 15, 2018 :
    It is called "Apps", which you can find in Personal. Then "List applications" Then the 3 buttons in righthand top corner. Select System apps. Bluetooth. Storage. Clear cache.
  16. sirdedlock Eclair Jan 15, 2018
    sirdedlock, Jan 15, 2018 :
    Did you upgrade to Oreo. A lot of people, including myself, are having major issues with Bluetooth after the update.
    ramon8 likes this.
  17. G_Andrew_Blackney_LUPJ Donut Jan 15, 2018
    babone likes this.
  18. anuragthukral Cupcake Sep 7, 2018
    anuragthukral, Sep 7, 2018 :
    You can go in settings apps applist from top corner show system apps select bluetooth force stop
  19. lazy85 Cupcake Nov 13, 2018
    lazy85, Nov 13, 2018 :
    Same problem for my OP5 and Bluetooth car radio.
    Iphone and OnePluse 3 work fine. OP5 no!
    Please help us!
  20. stein14 Donut Nov 13, 2018
