2
Bluetooth issue.
  1. sanoopkurup
    Cupcake Sep 12, 2018
    sanoopkurup , Sep 12, 2018 :
    Unable to connect calls with Bluetooth devices. Unable to check he option "Use for" "phone calls".
    Sampath Sunkesala and DaniReina5 like this.
  2. alweekes
    alweekes , Sep 12, 2018 :
    I'm having exactly the same problem on my oneplus5, running OxygenOS 5.1.5.
    Clearing the Bluetooth app cache, or resetting network connections provides a temporary fix, but the problem always returns.
  3. G_Gerardo_Echave_AjoX
    G_Gerardo_Echave_AjoX , Sep 12, 2018 :
    I´m having the same problem since the last update (5.1.5) in my 5T. It won´t connect to my car and other connectios ane unstable. As alweekes says it can be solved cleaning up chache but it won´t last long
  4. OMI805
    Cupcake Oct 3, 2018
    OMI805 , Oct 3, 2018 :
    Same issue:
    When I connect the Bluetooth headphones , phone function is not working . in device history its shows phone function is not enabled. When tried to enable it's not working.
  5. L1513891879992
    Cupcake Oct 18, 2018
    L1513891879992 , Oct 18, 2018 :
    Hi Moderators / Tech Guru's,
    We are facing this Bluetooth connection issue from long. Can anyone of you please look into this and help us to resolve this issue!!
    Or shall we consider that OnePlus support has stopped listening their users issues after OS upgrade!
  6. Sampath Sunkesala
    Donut Oct 22, 2018
  7. NiKuchroo
    Cupcake Oct 23, 2018
    NiKuchroo , Oct 23, 2018 :
    I too faced a similar issue and reported the bug. OnePlus will apparently fix this in the next update. Meanwhile as a workaround go to settings>Location>(3dots)>scanning>disable bluetooth scanning. This could solve the problem
