Network/Connectivity Bluetooth issues after 10.3.6?
  1. ramik
    Gingerbread Oct 21, 2020
    ramik , Oct 21, 2020 :
    Greetings
    Since I installed the 10.3.6 rom on my op6 my galaxy watch 1 can't download/update apps and watch faces on the watch, there is a bluetooth connection, notifications work, but for some reason updating apps doesn't work
    Anybody else had some issues with bluetooth?
  2. Rajendra.Bhat
    Jelly Bean Oct 21, 2020
    Rajendra.Bhat , Oct 21, 2020 :
    Check this it might help you https://support.oneplus.com/app/answers/detail/a_id/346
  3. mohd_areeb
    Honeycomb Oct 22, 2020
    mohd_areeb , via OnePlus 6 , Oct 22, 2020 :
    Try a fresh connection between your phone and your watch.
    For that go to settings>Bluetooth , disconnect your watch and tap on forget.
    Try to reset settings on your watch too and then reboot your phone and watch.
    Now try a fresh connection and see if it works!
    (Uninstall updates on your phone related to your watch or any app for it and then re-install)
