Bluetooth issues
  1. Lamarhurlston Donut May 22, 2019
    Lamarhurlston, May 22, 2019 :
    Hello yesterday May 21 I got my OnePlus 7 pro 6/128gb
    everything is working fine except the Bluetooth I can't connect on my car.
  2. deflemonkid Honeycomb May 22, 2019
    deflemonkid, May 22, 2019 :
    I'm having bluetooth issues also. Got mine today and i can pair with my macbook pro but cannot connect to my bluetooth headphones. My ticpods free dont show up in the bluetooth menu at all and i have a cheap pair of bluetooth headphones that show up when i try to pair a new device but when i click on it it does nothing.
    Lamarhurlston likes this.
  3. Lamarhurlston Donut May 22, 2019
    I been trying to connect the Bluetooth on 3 different cars and still doesn't work and random the gestures doesn't work too on my 7 Pro but I talk to OnePlus they are working on the update to fix this specific problems rolling on 3-48hrs.
    deflemonkid likes this.
  4. deflemonkid Honeycomb May 22, 2019
    Hopefully its just a software issue so.
    I managed to get my cheap bluetooth headphones working after a reboot of the phone. Not sure if that was the fix as i'd restarted it several times already in trying and it still didnt recognise my ticpods.
  5. Lamarhurlston Donut May 22, 2019
    Hopefully too! And I do all that 1° -System- Reset Wi-Fi, mobile & Bluetooth. then they tell me to do 2° Wipe cache after still the same with the issues the last thing they tell me do a 4° Factory reset and the issues still there so they say is update coming. But let me know if you make it work.
  6. CShiunL Cupcake May 23, 2019
    G_Ri likes this.
  7. Lamarhurlston Donut May 23, 2019
    Lamarhurlston, May 23, 2019 :
    I tried on Toyota tundra 2014 and Mercedes Benz 2019 and
    doesn't work I can't even pair with my old device OnePlus 6.
  8. deflemonkid Honeycomb May 30, 2019
    deflemonkid, May 30, 2019 :
    I finally got my headphones connected. I'm afraid i cant be much help as i'm not sure how it worked though. i just tried it again yesterday and they just connected straight away. Hope ye got sorted with your issues.
  9. Lamarhurlston Donut May 30, 2019
  10. deflemonkid Honeycomb May 30, 2019
    It wasnt actually the update fixed mine. got the headphones working yesterday but only got the update today. So long as it works tho i'll not complain :p
    Glad ya got yours sorted too.
  11. N1558429280365 Cupcake May 30, 2019
    N1558429280365, May 30, 2019 :
    Got the same problem. Could first connect and for a few days it worked fine. Suddenly no connection, and I can not pair it again. My Samsung S7 got problems with the BT of this car the last 3 years
  12. D1553144305415 Donut May 31, 2019
  13. Lamarhurlston Donut May 31, 2019
    Lamarhurlston, May 31, 2019 :
    You have to make sure u got active "Discoverable" - Visible to all nearby Bluetooth Devices
    Is on Bluetooth section
    D1553144305415 likes this.
  14. N1558429280365 Cupcake Jun 1, 2019
  15. Lamarhurlston Donut Jun 1, 2019
    Lamarhurlston, Jun 1, 2019 :
    Did u try on setting- (System) - Reset options - ( Reset Wi-Fi, mobile & Bluetooth) maybe that help u
  16. Carlito72 Cupcake Jun 12, 2019
    Carlito72, Jun 12, 2019 :
    I have same issue since last system update in June 3, 2019. I hope OnePlus can solve this.
  17. G_Ri Cupcake Jun 20, 2019
    G_Ri, Jun 20, 2019 :
    mine works with 2015 RAM with Uconnect. does messaging also
