Bluetooth issues via OnePlus 8 Pro
  1. Kelvinkai
    Donut Apr 6, 2021
    Kelvinkai , via OnePlus 8 Pro , Apr 6, 2021 :
    Hi all
    Has anyone encountered bluetooth issues with their one plus 8 pro?
    I having bluetooth issues where my wireless earbuds will disconnect once in awhile for a few seconds.
    P.S I tried resetting my connection settings but it still happened. Hoping someone can have a solution for this issue. Thanks all
  2. hbk1402
    Honeycomb Apr 7, 2021
  3. #3
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 7, 2021
    Parkourbrad likes this.
  5. Parkourbrad
    Eclair Apr 7, 2021
    Parkourbrad , Apr 7, 2021 :
    To be fair I've never had an issue with Bluetooth earbuds. Only watches or smart bands
  6. Kelvinkai
    Donut Apr 7, 2021
    Caomhin likes this.
  7. Kelvinkai
    Donut Apr 7, 2021
    Kelvinkai , via OnePlus 8 Pro , Apr 7, 2021 :
    Ya kinda annoying but mine doesn't auto connects back but it takes about 5-10s ish
    Caomhin likes this.
  8. Kelvinkai
    Donut Apr 7, 2021
    Caomhin likes this.
  9. McLarenMania
    Gingerbread Apr 8, 2021
    Caomhin likes this.
  10. pgrey
    Ice Cream Sandwich Apr 8, 2021
    pgrey , Apr 8, 2021 :
    If you turn-off Bluetooth (on the phone) while you're not using it, it won't use any additional battery with the "App Optimization changes".
    The "Sleep Standby Optimization" and "App Optimization" would have some effect; how much depends a LOT on your array of app(s), and how "well behaved" they are themselves, in terms of background processing.
    I have literally zero Bluetooth issues with headsets and other audio (car, etc), but occasionally I have a problem with my cycling computer, or fitness watch, but those are occasional, at-best (Android 11 release fixed *almost* all of those).
  11. Kelvinkai
    Donut Apr 8, 2021
    Kelvinkai , via OnePlus 8 Pro , Apr 8, 2021 :
    Hi I'm using jabra elite active 75t at the moment
    McLarenMania and Caomhin like this.
  12. Kelvinkai
    Donut Apr 8, 2021
    I did notice the issues gets better after the update (less frequent) and after I did the above steps mentioned it did get slightly better.
    It is much better than previously so I'm glad but hopefully it will be completely gone after a few days. Will keep you guys updated.
    Anyway, thanks for your help so far, had been really insightful!
    P.S have around 5 hours ish of screen time with 19% left so I guess its still acceptable.
    Parkourbrad, McLarenMania and Caomhin like this.
