Bluetooth not working on calls since 5.1.5
  1. mackylos
    Cupcake Aug 30, 2018
    mackylos , Aug 30, 2018 :
    As the title says Bluetooth for calls has stopped working since the 5.1.5 update.
    Please make this a top priority to be rectified as I find it very difficult to work while holding the phone based on the nature of my work.
  2. maazen
    Donut Aug 30, 2018
    maazen , Aug 30, 2018 :
    Seriously wtf. update to 5.1.5 and I can't even connect to Bluetooth. this is RIDICULOUS! I love this phone but since I got it I've had nothing but Bluetooth issues, but this one is the worst one yet. Why? This is unacceptable and shouldn't happen in 2018.
    Please fix.
    Thank you.
    Riteshcs2010 likes this.
  3. mackylos
    Update....I have a temporary workaround for lack of Bluetooth with calls. I am using a third party phone dialler.
  4. Riteshcs2010
    Riteshcs2010 , Aug 30, 2018 :
    I am also facing the same issue.. not able to connect my Bluetooth for the calls. Really horrible..
  5. Riteshcs2010
    No response from one plus team
  6. franferparra
    franferparra , Aug 30, 2018 :
    I am facing the same issue, when you go to the Bluetooth connected devices and select the car connection configuration ( wheel icon next to the device name)there you can see that the income calls check box is empty and the system is not allowing you to mark it.
    if you restart the cell the car connection has the incoming calls check box marked. I don't know when it goes back to unchecked again.
    lot of people are using the phone as a work tool and we need car connectivity. please short it out ASAP
    thanks
  7. Ma_Fi
    Eclair Aug 31, 2018
    Ma_Fi , Aug 31, 2018 :
    Hi, here is the solution I got from OnePlus
    Hi dear sir/madam, for this Bluetooth issue, we created a repairing patch which can fix this issue completely, BUT it will risk Google Pay failure, means Google Pay will not be functional. If you are willing to install this patch(only for the build number O2 Stable 180808), please download it from our Google Drive, links are here below, please choose the right model of your phone to download. After download it, put it under the root of Storage, then go to settings> system updates> right top menu> local upgrade.
    OnePlus 5: https://drive.google.com/open?id=1scDKrHZXSd45RQGzcUFWEsblpSYWbWnb
    OnePlus 5T: https://drive.google.com/open?id=1J0ltrRZZzNB-NBE3ELJe4_ZmFaPG_sPy
    If you installed this repairing patch, please keep noted if the bugs get resolved or not, we will take care of it. Thanks for your cooperation and great days to you.
    franferparra likes this.
  8. meme902
    Cupcake Aug 31, 2018
  9. meme902
    meme902 , Aug 31, 2018 :
    perfect solution really
  10. franferparra
    meme902 likes this.
