Bluetooth phone call enabled options issues
  1. azharbasha
    Cupcake Sep 12, 2018
    azharbasha , Sep 12, 2018 :
    hi, when I Connect to Bluetooth headphones or connect to phone by default phone calls is doing disabled as shown in the picture...it I will get enable once I rebooted the phone...So every time I trying to connect with Bluetooth I need to restart my phone which is too much frustrating..this is being happened from 10 days...
    request to help on this issue asap
  2. azharbasha
    I tried the below suggestions in one of the discussion and it works for me...
    "Had this problem recently. If you turn off Bluetooth scanning in location settings it will fix the problem. Settings, location, 3 dots, scanning, Bluetooth scanning off."
    not sure if this setting is making any mess in other place.
    anuragthukral likes this.
  3. alweekes
    alweekes , Sep 12, 2018 :
    Clearing the Bluetooth app cache, or resetting network settings provides a temporary fix for this issue, but it always returns.
  4. azharbasha
    Cupcake Sep 13, 2018
    azharbasha , Sep 13, 2018 :
    please follow my above mentioned steps ... location setting for Bluetooth Scanning will works
  5. F_Shiva_Tink_jzUA
    Froyo Sep 13, 2018
    F_Shiva_Tink_jzUA , Sep 13, 2018 :
    am using op6 the same issue exists rite frm day 1 and raised a bug before 1 and half month but no response frm op team.... useless phone dont even hav a basic feature Bluetooth to work as expected....
  6. RohirNaik
    Cupcake Nov 1, 2018
    RohirNaik , Nov 1, 2018 :
    Same issue facing by me too. Phone Calls not supporting on bluetooth connected to handsfree or car audio. Clearing the Bluetooth app cache provides a temporary fix for this issue, but then again same issue starts.
    Now i did as said abve by @azharbasha and the issue is gone now. Let me try this for another few days. But this sorted out my issue. :)
  7. vinaysharmajpr
    Cupcake Jan 28, 2020
    vinaysharmajpr , Jan 28, 2020 :
    Phone: One plus 7 pro
    Bluetooth headset: Sennheiser PXC550
    Issue: while connected to headset, if I make a phone call it defaults to phone audio, all three options i.e. speaker, phone audio, bluetooth headset are available to select but can only select speaker or phone audio.
    Resolution steps: cleared network cache, phone cache, Bluetooth app stop, cache reset etc... nothing worked.
    Final solution: Settings, location, 3 dots, scanning, Bluetooth scanning off. thanks @azharbasha
    So far it's good, I will update if it reoccurs.
  8. V1513621021906
    Cupcake Oct 26, 2021
    V1513621021906 , via OnePlus 9 Pro , Oct 26, 2021 :
    I have a very similar issue and have attempted the steps above.
    Unfortunately toggling Bluetooth scanning of has not been effective for me.
    Anybody got any other suggestions?
