Bluetooth problem via OnePlus 7 Pro
  1. amirpz
    Cupcake Sep 24, 2021
    amirpz , via OnePlus 7 Pro , Sep 24, 2021 :
    my OnePlus 7pro just find many address in new pair in Bluetooth and cant connect with any device's 😐 my JBL headphones my airpods my car and ...
    i deleted my Bluetooth catch and restart it before but not working yet,
  2. amirpz
  3. nerdkabir
    Jelly Bean Sep 24, 2021
    nerdkabir , via OnePlus 7 Pro , Sep 24, 2021 :
    Can you try resetting your network wifi Bluetooth settings? Its under factory reset option. It will hopefully rectify this.
    Also, it started suddenly? Or you updated your phone?
    Artemus likes this.
  4. amirpz
    i restarted still not working. my version is the last this problem occurred after the new version.
  5. the_o2
    OnePlus 9 Series Expert Community Expert Sep 24, 2021
    the_o2 , Sep 24, 2021 :
    Open the developers option
    ( Settings > About phone > tap the build number 7 times. Now go back to Settings > system )
    And disable the show Show Bluetooth devices without names if enabled.
    Artemus and nerdkabir like this.
  6. nerdkabir
    Artemus likes this.
  7. amirpz
    Cupcake Sep 26, 2021
    amirpz , via OnePlus 7 Pro , Sep 26, 2021 :
    I meant reset. I did it but it didn't work.
  8. nerdkabir
    Jelly Bean Sep 26, 2021
    nerdkabir , via OnePlus 7 Pro , Sep 26, 2021 :
    Kind suggestion, frame your sentence properly and do spell checks before asking for help. Its cumbersome for anyone who is trying to help you. Can't keep decoding your posts.
    Resetting Bluetooth Wi-Fi and network didn't help?
    What about the other user suggestion? Did you try that?
  9. amirpz
    I checked the developer settings and everything seemed to be OK. I think it is better to be a little kinder, maybe everyone will make a mistake.
  10. nerdkabir
    Artemus likes this.
  11. the_o2
    OnePlus 9 Series Expert Community Expert Sep 27, 2021
    the_o2 , Sep 27, 2021 :
    Rename you Bluetooth device name to something else, like your name instead of OnePlus 7Pro and then try.
  12. amirpz
    Cupcake Oct 4, 2021
    amirpz , via OnePlus 7 Pro , Oct 4, 2021 :
    I also tried this, it still does not work.
    I find some devices but they do not connect.
    I'm really upset about this problem that is not going to go away.
  13. the_o2
    OnePlus 9 Series Expert Community Expert Oct 5, 2021
    the_o2 , Oct 5, 2021 :
    In that case better to report it here
    https://forums.oneplus.com/feedback
  14. Srishti Chetry01
    OnePlus Bug Hunter Staff Member Oct 6, 2021
    Srishti Chetry01 , Oct 6, 2021 :
    In order to investigate this further we've sent a direct message please check for the same.
    Thanks & regards,
    Srishti.
