Bluetooth problem via OnePlus 7T
  1. srealcuevas
    Cupcake Sep 28, 2021
    srealcuevas , via OnePlus 7T , Sep 28, 2021 :
    Hello! I wanted to know if you have problems with the bluetooth to play multimedia. I have two headphones, one One Plus and the other not, and the car's bluetooth and none of them let me play the audio through them since yesterday, I can receive calls but when I connect a device the audio is played through the speaker and there is no way to change it.
    From the sat they have given me several options and none have served me, I only have to reset it from the factory but before doing so I wanted to know if there is someone with the same problem or if they know any other solution
  2. O1620341110957
    srealcuevas likes this.
  3. srealcuevas
  4. srealcuevas
  5. srealcuevas
  6. srealcuevas
  7. Drasm19
    Ice Cream Sandwich Sep 28, 2021
    Drasm19 , Sep 28, 2021 :
    Try resetting your cache from recovery.
  8. srealcuevas
  9. mjrtoo
    Eclair Sep 28, 2021
    mjrtoo , via OnePlus 7T , Sep 28, 2021 :
    I just tried this, we'll see how long it lasts. Odd that the issue seems to have just started popping up but the last is update was some time ago.
  10. W1592289258964
    Froyo Sep 29, 2021
  11. N1632980587825
    Cupcake Sep 30, 2021
  12. G_Pedro_Ortiz_dpbN
    Cupcake Oct 1, 2021
    G_Pedro_Ortiz_dpbN , Oct 1, 2021 :
    good morning, I have the same issue. I try the reset and don't work, delete all Bluetooth form the car and the other devices and don't work. I have a Oneplus 5T and before the last update was working perfectly. Maybe is a problem with the last ota.
    I hope to fine a solution for this problem.
    Thanks
  13. O1633234849511
    Cupcake Oct 3, 2021
  14. O1633234849511
    Cupcake Oct 3, 2021
  15. srealcuevas
    Cupcake Oct 6, 2021
  16. K1592840882263
    Cupcake Oct 19, 2021
  17. Bonhop
    Cupcake Oct 20, 2021
