Bluetooth problems with latest update
  1. tom79
    Eclair Feb 21, 2020
    tom79 , Feb 21, 2020 :
    Hi all,
    with latest update 10.3.1, my Bluetooth headset and others Bluetooth sound devices after some time start lagging, sound stop for some seconds then restart again and again.
    Disabling an enabling Bluetooth again fix it but is annoying.
    Happens even to others?
    jP1250 likes this.
  2. Caomhin
    KitKat Feb 21, 2020
  3. Massiv
    Donut Feb 24, 2020
    Massiv , Feb 24, 2020 :
    That doesn't work. Tired of these suggestions. Have done that, and completely reset/rebuilt twice, and no fix.
    What does work - temporarily - is to turn ON airplane mode, and while it is on, turn bluetooth BACK ON. Then you can either leave airplane mode on or turn it off, and you'll have perfect sound until your next bluetooth reconnect. Very frustrating to have to do this all the time.
    Massiv.
    jP1250 likes this.
  4. Caomhin
    KitKat Feb 24, 2020
    Caomhin , via OnePlus 6T , Feb 24, 2020 :
    I can only suggest to contact OnePlus directly to see if they have a solution for you.
  5. mischa1981
    Ice Cream Sandwich Feb 24, 2020
    jP1250 likes this.
  6. Massiv
    Donut Mar 13, 2020
    Massiv , Mar 13, 2020 :
    don't bother trying to upgrade out of the issue. Bought the 7T as a hope to get past the issue on my 6, and has the exact same problem. Sammy S10 and iPhones I have are all crystal clear. (True on 10.3.1 and 10.3.2)
