Bluetooth problems with Xiaomi mi band 3
  1. kouzelnik3
    Froyo Sep 22, 2018
    kouzelnik3 , Sep 22, 2018 :
    Hello all, since update to Android Pie, I cannot pair neither connect to Xiaomi mi band 3 which I has. Before I had updated to the Pie, it was all good but after that my mi band couldn't connect and it says something like it couldn't be connected. Is this a bug or am I doing something wrong? Thank you.
  2. B_Wrath
    Marshmallow Sep 22, 2018
    B_Wrath , Sep 22, 2018 :
    Unpair the device from your mi fit app, Unpair it from your bluetooth settings.. Then pair it again through your mi fit app...
    SeeBeeEss likes this.
  3. kouzelnik3
    Froyo Sep 22, 2018
  4. argaar
    Cupcake Sep 23, 2018
    argaar , Sep 23, 2018 :
    I can't reconnect, I restarted my phone, bluetooth, unpaired from the app and bt settings, restart the app and checked all permission to see if them was granted (of course).
    It still won't pair again, the MiFit app start searching for the band and then timeout without success
  5. ericamodena
    Cupcake Sep 26, 2018
    ericamodena , Sep 26, 2018 :
    @argaar Have you solved? I've turned off and on bluetooth, removed pairing with mi band 3 from settings, rebooted several times but for me it didn't worked. :-(
    Thanks, bye
    Erica
  6. argaar
    argaar , Sep 26, 2018 :
    Yes, I used to have both "MiFit" and "Notify & Fitness for MiBand" and I just noticed the last one can estabilish a connection sometimes. So I make a backup of my settings and uninstall it (force stop wasn't enough), reboot the phone and the miband (keep the Button pressed/touched for at least 10s).
    When the phone restarted I looked in bt settings just to be sure there was no evidence of previous device, and perform the pairing from the official MiFit app
    The reason for previous failure was probably to be addressed to Notify&fitness that retains a sort of "Lock" on miband
    P1518772424620 likes this.
  7. ericamodena
    @argaar I use app "Notify & Fitness for MiBand" for everything and Mi Fit just for updates. Unistalling Mi Fit and just re-pairing "Notify & Fitness for MiBand" with MiBand 3 worked perfectly also for me!!!
    Thanks! Bye!
    Erica
    argaar likes this.
  8. kanariepietje
    Cupcake Oct 13, 2018
    kanariepietje , Oct 13, 2018 :
    Another solution might be to go to your apps, search mi app, storage, clear cashe and or clear storage. Go to mi app and login/ approve the permissions. Should work again. Had the same problem with not connecting.
    Edit: typo
  9. B_Wrath
    Marshmallow Oct 13, 2018
    B_Wrath , Oct 13, 2018 :
    Why should they clear cash?? Is this some sort of money laundering???
    And why post in two week old thread??? They already have the problem solved..
  10. Nikhil S Jain
    Cupcake Nov 24, 2018
    Nikhil S Jain , Nov 24, 2018 :
    i'm not able to reject calls or mute calls via mi band 3 even though its connected to my oneplus 6t phone please help me with this issue.
  11. Praty_28
    Jelly Bean Dec 2, 2018
    Praty_28 , Dec 2, 2018 :
    What i do to reconnect is, i go into bluetooth settings of the phone and then forget the mi band 3. Then i go back to notify and fitness app and just hit re-pair band and it gets connected instantaneously no need to uninstall/reboot.
    P.S - I only use notify and fitness app.
  12. L1547793707093
    Cupcake Jan 18, 2019
    L1547793707093 , Jan 18, 2019 :
    Hello,
    Today after updating the miBand 3/mifit my son accidentally pressed something on miBand 3 which unpaired the device from the app. I was then unable to repair it , tried turning Bluetooth off/ on etc and finally told the iPhone to forget the device.
    I have since reset the network settings of the iPhone but the Bluetooth is still unable to find the fitness band. Unfortunately all the relevant forums state that you need to turn off and then back on the device but miBand 3 does not have such an option.
    I have also uninstalled and reinstalled mifit but that did not work either
    So now I have two problems.
    First I need to see the band in my Bluetooth settings so I can re-pair them there then I need to do the same in mifit app which I was unable to do so before.
    Any suggestions?
  13. H1542746923873
    Cupcake Feb 13, 2019
    H1542746923873 , Feb 13, 2019 :
    Hi!
    I've the same issue. Any suggestions?
    Thanks a lot!
  14. Nutzy
    Donut Feb 18, 2019
    Nutzy , Feb 18, 2019 :
    Hello
    since i updated to Android 9 my oneplus 5t, i can't received notifications when SMS arrived. it's working well with WhatsApp and call but not SMS. I desintall mi fit, reinstall. I also dissaciated my band and reassociated,but when my husband sent me a SMS just after the reinstallation it's working few minutes / hours only.
    Any ideas?
    thanks
  15. szofdani
    Eclair Mar 15, 2019
  16. szofdani
    Eclair Mar 16, 2019
  17. ChrisNeo
    Eclair Mar 21, 2019
  18. ChrisNeo
    Eclair Mar 21, 2019
    ChrisNeo , Mar 21, 2019 :
    Is it possible to find it from a different place? Besides google google play?
  19. P1518772424620
    Donut Mar 27, 2019
    P1518772424620 , Mar 27, 2019 :
    I am using OnePlus 5t 8gb version, now i am buying MI band 3 and connect with OnePlus all are working well. Except the band didn't show incoming caller name and number. I will connect another phone model is vivo v11 pro. In that vivo mobile it shows caller name and number. What is the problem.
  20. DummyGod
    Cupcake Mar 27, 2019
    DummyGod , Mar 27, 2019 :
    Hi, I am not able to see caller name on My MI Band 3 also not able to silent the calls, I can only reject calls, can you please fix this issue with mi Band 3.
