Bluetooth speaker connectivity issues
  1. A1532534821675
    Cupcake Aug 24, 2018
    A1532534821675 , Aug 24, 2018 :
    The Bluetooth speaker/headset automatically gets disconnected whenever a notification is received. Everytime it changes the output device to phone speaker and I need to change it to Bluetooth speaker using the quick drop down from Notification area.
    If anyone knows how to fix the issue, please let me know.
    H1549263612669 likes this.
  2. the_o2
    Marshmallow Aug 24, 2018
    the_o2 , Aug 24, 2018 :
    Try this
    Go to settings then backup and reset and reset the network settings and restart your phone once..
    And enable the Bluetooth scanning from wifi settings..
    If still having problems report here
    https://forums.oneplus.com/feedback
    A1532534821675 likes this.
  3. nabbed
    Honeycomb Aug 24, 2018
  4. the_o2
  5. nabbed
    nabbed , Aug 24, 2018 :
    Aside from basically erasing network settings and interfering with apps that use them?
    Let me tell you a short tale of Network Settings reset.
    I was in a service chat with OP tech support for a completely unrelated issue of Bluetooth, and they asked me to do the Network Settings reset. I complied.
    After the reset, my voice calls would no longer work, but data would. I had to mess with mobile carrier settings for like 15 minutes before I figured out how to make things work again.
    Also, my Huawei Watch went into a bootloop, from which I couldn't make it recover. Even after trying to boot into recovery, I had to wait until it ran out of battery and shut down, before it recovered itself. Now, this is the watch problem, of course. But it does answer your question - what harm???
    In a more general note, I have used Network Settings reset a number of times in the past with 3 different phones for different problems. It has NEVER solved any problems.
  6. the_o2
    In my case my wifi and Bluetooth connectivity solved by doing this..
    Apart from this if you have any solution post that don't tell me do the factory reset, because that actually sucks...
  7. nabbed
    You do you, boo.
  8. the_o2
  9. A1532534821675
    Thanks guys but I also don't intend factory reset option. I think i shall wait for some more expert advices, like some1 from OP support system. But i appreciate ur suggestions.
  10. nabbed
    If you want someone from OP support system, this isn't the place to post. These are community support forums - users helping users.
    Official support comes in the "Bug Reports" forum or by filing a "Complaint" in main OP Support web page.
