[Submitted] Bluetooth Volume Fluctuation
  1. ashishzone
    Eclair Dec 23, 2018
    ashishzone , Dec 23, 2018 :
    This problem is arises when a Bluetooth enabled headphones or earphones are connected to the device. There is a lot of Volume Fluctuation which occurs automatically even without any manual engagement while playing any media content such as songs and videos. The volume constantly keeps fluctuating though the volume levels are not modified manually.
  2. Catalin_Buzescu
    Jelly Bean Dec 28, 2018
    Catalin_Buzescu , Dec 28, 2018 :
    Hi there.
    I had the same problem but a member here pointed out a solution which worked for me:
    * connect a wired headphone into the jack of your device
    * go to sound--> audio tuner and click that off
    Now, please try again and tell me if it worked for you.
    Cheers!
    ashishzone likes this.
