Bluetooth
  1. sreejith krishnan
    Froyo Mar 31, 2017
  2. ZacharyX8
    Gingerbread Mar 31, 2017
    ZacharyX8 , Mar 31, 2017 :
    What is your problem? I'd suggest restarting the phone or checking for another update.
  3. sreejith krishnan
    Froyo Apr 1, 2017
    sreejith krishnan , Apr 1, 2017 :
    The Bluetooth will work perfectly after reboot. Am using a Bluetooth headset and if i have connect it, i turn on the Bluetooth and it wont turn on. Then i restart the device and it works perfectly.
    Althafkanneth likes this.
  4. Princy.harpreet
    Cupcake Apr 4, 2017
    Princy.harpreet , Apr 4, 2017 :
    Having the same issue.my Bluetooth app is not responding. please help. tried rebooting and off/on thing for a couple of times.
  5. gursehajharika
    Cupcake Apr 4, 2017
    gursehajharika , Apr 4, 2017 :
    Just try restarting and if that doesn't work try a hard reset if that also doesn't work then flash the OS again
  6. pritshah710
    Donut Apr 4, 2017
  7. G_Chris_Murphy_ymNT
    Eclair Apr 4, 2017
    G_Chris_Murphy_ymNT , Apr 4, 2017 :
    either reset phone or contact one plus it also may be if you have dropped the phone it could have moved the bluetooth chip loose.
  8. Ma771a99
    Cupcake Apr 5, 2017
  9. Arjun_Patel_6878
    Froyo May 2, 2017
    Arjun_Patel_6878 , May 2, 2017 :
    Bluetooth issues are not solved yet...
    i m facing the same.....
    it stops working in between song... or call and voice transfered to handsate...
    also .. equiliser is not
    optimised. it is not supported quite well and not supporting other devices
  10. Althafkanneth
    Cupcake May 21, 2017
    Althafkanneth , May 21, 2017 :
    Same here.. Finally i found someone with same complaint.. Did u tackle it?
    rangarajsr likes this.
  11. Y1512630906710
    Cupcake Dec 7, 2017
    Y1512630906710 , Dec 7, 2017 :
    Bluetooth won't allow phone access to my car. I have checked the settings, I tick the phone option but it unticks it again. previously worked very well. I have tried rebooting several times. also the data allowance counter has gone haywire and screen sensitivity is reduced ....
