Joseph Hadder , via OnePlus 7T Pro , Oct 3, 2020 : Hi, I've recently bought what is supposed to be a new oneplus 7t pro from amazon.ae, and the onpluse diagnostic app is telling me that my battery is 96% healthy, os that normal or this means that the device was actually used before ? Also it is a single sim, not a dual one. Thanks.
G_plusone , Oct 3, 2020 : The battery health App is Probably bad. Check out the seller on Amazon though
Praty_28 , Oct 3, 2020 : Check the date of manufacture of the device, it is a common misconception that a new device will always come with 100% battery capacity. Battery degradation occurs even when the device is not in active use. As you have purchased an older model there is a chance that it was manufactured a year ago and the battery for it was manufactured a few months prior to assembly. If a battery is left unused for over a year it is very much possible for it's health to degrade to a certain extent.
Max.Mar , Oct 3, 2020 : Check the manufacturing date of your device.. batteries tend to degrade over time even when not in use. 96% won't worry me that much.
Joseph Hadder , via OnePlus 7T Pro , Oct 3, 2020 : I suppose, but I found that not only I found this issue from the same seller.
Tokolozi , Oct 3, 2020 : https://www.imei.info/ I would suggest checking here to see if they have info about your device. While not 100% accurate. It would at least give you some idea.
Joseph Hadder , via OnePlus 7T Pro , Oct 3, 2020 : Much appreciated. EDIT: As you can see, I got scammed. And the seller on amazon was Oneplus .
DerNachbar , via OnePlus 7T Pro , Oct 4, 2020 : My new 7T Pro was manufactured in July 2020. I use it the 3rd day now and diagnostic app shows 93%. Just wait until you charged/discharged the phone a couple times.
Bobbie63 , Oct 4, 2020 : It doesn't tell you when it was produced, it only tells you when the model release was and if it's sold by OnePlus, what makes you think it's single Sim and not dual?
Joseph Hadder , via OnePlus 7T Pro , Oct 4, 2020 : As you can see here it has two entires. And here is a photo of the sim tray.
DerNachbar , via OnePlus 7T Pro , Oct 4, 2020 : 2nd sim belongs on the backside. There is room for a 2nd sim unless it's a T-Mobile version.
Joseph Hadder , via OnePlus 7T Pro , Oct 4, 2020 : I bought it from UAE amazon,its not T mobile version.
BeingIncog , Oct 4, 2020 : you can put two sims either sides of the sim tray, back and forth............................
