Bricked my phone with a catch ?
  1. kels0605
    Honeycomb Oct 8, 2014
    kels0605 , Oct 8, 2014 :
    I bricked my oneplus tried following what this post told me to do https://forums.oneplus.net/threads/solved-soft-bricked-my-opo.95668/
    Since recovery isn't working, you should use fastboot
    Note: This will wipe your phone of everything!!
    1. Download and extract contents of this to your desktop
    2. Download and install universal adb drivers if you haven't already from here
    3. Download and extractthis into your platform-tools folder from step 1 (there are 15 or so files that you should place at the root of the platform-tools folder)
    4. Hold down shift + right click in platform-tools folder and click "open command line here"
    5. Type in all these commands in order one at a time(some of them may take some time so be patient), your phone must be in fastboot mode (power button + volume up) and must be plugged in to your computer:
    fastboot oem unlock
    ^^^*** This step will wipe your device!! (Once it finishes unplug your device, go into fastboot mode again, and then plug it back in)
    fastboot flash modem NON-HLOS.bin
    fastboot flash sbl1 sbl1.mbn
    fastboot flash dbi sdi.mbn
    fastboot flash aboot emmc_appsboot.mbn
    fastboot flash rpm rpm.mbn
    fastboot flash tz tz.mbn
    fastboot flash LOGO logo.bin
    fastboot flash boot boot.img
    fastboot flash cache cache.img
    fastboot flash recovery recovery.img
    fastboot flash system system.img
    fastboot flash userdata userdata_64g.img
    fastboot reboot
    this did not work its telling me that the phone is not unlocked ,which I'am assuming is the boot loader twrp is installed btw I literally deleted everything that can be deleted except for internal files such as pictures
  2. BigE1995
    Ice Cream Sandwich Oct 8, 2014
  3. adel1406
    Gingerbread Oct 8, 2014
  4. gmo8492
    Lollipop Oct 8, 2014
  5. kels0605
    funny thing is i was just trying to reset it might have to buy an iphone tmrw :( i cant be without a phone !!!!!
  6. carbine30
    Marshmallow Oct 8, 2014
    carbine30 , Oct 8, 2014 :
    Not everything posted at the forums is right, search for more tips next time to avoid such a fatal error. all the best :)
  7. BigE1995
    BigE1995 , Oct 8, 2014 :
    You would be better off with a note3 or s5, or better yet, the lg g3. IPhone is not worth it
    Oneyedmonkey and Killua.Zoldyck like this.
  8. go for.android13
    Jelly Bean Oct 8, 2014
    go for.android13 , Oct 8, 2014 :
    Sad day...:( we all feel the pain for you and your late beloved one+one should Seine write a eulogy for the resent lost
  9. kels0605
  10. gmo8492
  11. LeighS
  12. go for.android13
    Sure if I had the device iny hands with issue and knowing exactly what has been done to if to get to this state then I would be able to fix but on limited info and not having the opo in hand in the same state I cannot help but you have given a bunch of helpful info for someone to be able to just not me
  13. Chym3ra
    Froyo Oct 8, 2014
    Chym3ra , Oct 8, 2014 :
    Try manudroid tool at xda.
    Check your drivers
  14. Aaahh
  15. Aron Gustafsson
    Froyo Oct 30, 2014
    Aron Gustafsson , Oct 30, 2014 :
    Your sentence saved me. I was having some truble with my phone and this was just what i i wanted. Thanks! :)
  16. Dlhoa1
    Eclair Nov 23, 2014
