brightness control
  1. R1567574336111
    Cupcake Sep 24, 2019
    R1567574336111 , Sep 24, 2019 :
    I there a way I can have my brightness control on the top of the screen when I swipe down instead of having to swipe down twice, my Galaxy s8 had that option for me to pick what I wanted does this also have it?
  2. J1562056193961
    Cupcake Oct 2, 2019
    J1562056193961 , Oct 2, 2019 :
    No, OnePlus doesn't have this option.
    Even I have used Galaxy S7, it had this option. But OnePlus didn't give this option.
    R1567574336111 likes this.
  3. Amatory
    Gingerbread Oct 2, 2019
    Amatory , via OnePlus 7 Pro , Oct 2, 2019 :
    lol. not that the brightness ever works properly. it's my biggest gripe with this phone. I love it. but the auto brightness is diabolical!
  4. Amatory
    Just found a very interesting app called BFC brightness controll. adds a very tiny sun icon on the very rh side of the screen. hardly visible. pushing it up. and down changes your brightness instantly. no need to even pull the tray down. works good.
    Be sure to set your brightness at max before you press ok.
    hope this helps.
  5. bd0zer
    Cupcake Oct 2, 2019
    bd0zer , Oct 2, 2019 :
    Auto-brightness/dimmin is horrible. When it decides to darken in a dim room, it goes way too far down. And sometime when pulling from pocket it's set way too low and after about 10 seconds (which seems like forever) it adjusts up. Maybe there should be an aggressiveness setting with the auto-dimmer. IDK, but something has to be better than this
  6. Amatory
    Gingerbread Oct 4, 2019
  7. Amatory
    Gingerbread Oct 14, 2019
  8. Narayan_Srinivasan
    Cupcake Oct 16, 2019
    Narayan_Srinivasan , Oct 16, 2019 :
    Very slow in adjusting the brightness when exposed to light and vice versa.. Horrible.. And brightness is too low in low lit areas. Need to adjust them constantly.. .. And in lowlight screen flickers while scrolling.. Please patch this immediately..
  9. Amatory
    Gingerbread Nov 8, 2019 at 1:48 PM
