12
Other brightness sensor/proximity sensor
  1. raducustancu
    Gingerbread Nov 26, 2016
    raducustancu , Nov 26, 2016 :
    will you ever make that brightness sensor work? it's pretty much useless, it does not dim the screen enough at night
    same for the proximity sensor, the screen stays on while calling
  2. G_Ovi_-_tZFm
    G_Ovi_-_tZFm , Nov 26, 2016 :
    I admit both sensor being eratic ,especially the proximity one since the brightness was mostly fixed.
    Very often I find myself in the middle of the call with screen on and randomly interacting with it with the ear or face.
    (salutare Răducule ! :) )
  3. Burgess85
    G1562101414113 and raducustancu like this.
  4. OkashaBasha
    Cupcake Nov 26, 2016
  5. Guna0969
    Froyo Nov 26, 2016
    Guna0969 , Nov 26, 2016 :
    I too hope Nougat fix this issue... Adaptive brightness are useless most of the times...
  6. Hari Naraayana Desikan
    Cupcake Nov 27, 2016
    Thiru_kacha likes this.
  7. Jaaved ahmed
    Cupcake Dec 11, 2016
  8. skd1
    skd1 , Dec 11, 2016 :
    same here... the screen turns up while on call with phone pressed to ear... sensor not working fine... one plus, please rectify this issue...
  9. G_Gutu_Cosmin_SsMx
    Cupcake Jan 4, 2017
  10. Angaiz Khan
    Cupcake Feb 13, 2017
  11. Sunnykundnani
    Donut May 29, 2017
  12. tetelatulipe
    Cupcake Jun 13, 2017
  13. F_Diganta_Koner_WIXu
    Jelly Bean Jun 13, 2017
  14. H1541483470631
    Cupcake Nov 6, 2018
    H1541483470631 , Nov 6, 2018 :
    I have the same problem with proximity sensor. my screen won't turn off during a call using Allapp, imoHD, Snapchat and other third party apps. is there a way around this.
  15. Tinybeetle
    Gingerbread Nov 6, 2018
    Tinybeetle , Nov 6, 2018 :
    The proximity sensor hasn't worked correctly on my OP3 for so long that I don't even remember when it did work. And the ambient light sensor is very erratic. It works fine at night, but during the day it will dim my phone to practically unreadable levels at random times. I often must manually adjust the brightness during the day.
  16. Thiru_kacha
    Cupcake Nov 14, 2018
  17. GANAPATHI SUBRAMANYAM J
    Froyo Jan 28, 2019
  18. m.eissa
    Cupcake Feb 12, 2019
    m.eissa , Feb 12, 2019 :
    Safe mode fix's it for me.
    I had the same issue [e]1f614[/e] and contact the support team, they suggested to restart into safe mode and test and the phone work normally and after restarting in the normal mode again I
    the phone work great.
    Safe Mode Steps:
    Press and hold the Power key, which would show up “Power OFF” and “Restart” options
    Tap and hold on “Power OFF” option on screen
    “Reboot to Safe Mode” option will appear on the screen
    Please proceed by tapping “OK”
    The device shall reboot into Safe Mode and Safe Mode Icon will appear on the bottom left corner of your screen
