Answered BT Audio Issue! via OnePlus 8 T-Mobile
  1. itsthane
    Cupcake Oct 19, 2021
    itsthane , via OnePlus 8 T-Mobile , Oct 19, 2021 :
    I have a OnePlus 8, a little over a year old.
    I also have OnePlus buds, and some Jib BT buds as well and there is an issue with the connection where the audio will be playing as it should through the Bluetooth devices but said audio or video will pause, and all subsequent audio will play through the phone however phone calls will still play through the connected Bluetooth device.
    I've reset phone, reset Bluetooth and network, disabled and re-enabled absolute volume, made sure audio setting on said Bluetooth is enabled, and cleared my cache on phone through bootup process. Not sure what else to do.
    Also, I've noticed when watching videos on phone, it will occasionally pause and play through the other speaker as if on a phone call and sometimes when adjusting the volume then on it will show the option for a call as if in one, but I would not be in a call. May be related.
    Photo attached demonstrates the call detection.
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 19, 2021
    Artemus , Oct 19, 2021 :
    Do you have Alibaba installed on your phone?
  3. itsthane
    I did, and I have promptly removed it because that response was very targeted haha. I'll see if I experience the issue from here on out, thanks for the advice!
    McJader and Artemus like this.
  4. G_Bryan_Surrett_ytpz
    Cupcake Nov 25, 2021 at 4:35 PM
    G_Bryan_Surrett_ytpz , Nov 25, 2021 at 4:35 PM :
    I have had the same issues recently on my 8t. I uninstalled Alibaba, so we'll see....
    Voilá! Uninstalling Alibaba gave me back my bluetooth audio. Hmmm. That's definitely a programming issue--or an invasive app.
  5. Gav_W86
    Moderator Moderator Nov 25, 2021 at 8:04 PM
    Gav_W86 , Nov 25, 2021 at 8:04 PM :
    Invasive I think, that app has quite a list of permissions (from the Play store listing):
    This app has access to:
    [​IMG]Device & app history
    • retrieve running apps
    [​IMG]Device ID & call information
    • read phone status and identity
    [​IMG]Photos/Media/Files
    • modify or delete the contents of your USB storage
    • read the contents of your USB storage
    [​IMG]Phone
    [​IMG]Storage
    [​IMG]Camera
    • take pictures and videos
    [​IMG]Wi-Fi connection information
    • view Wi-Fi connections
    [​IMG]Location
    • precise location (GPS and network-based)
    • approximate location (network-based)
    [​IMG]Microphone
    • record audio
    Other
    • capture video output
    • receive data from Internet
    • connect and disconnect from Wi-Fi
    • view network connections
    • reorder running apps
    • change your audio settings
    • run at startup
    • pair with Bluetooth devices
    • control flashlight
    • prevent device from sleeping
    • disable your screen lock
    • control vibration
    • full network access
    • draw over other apps
    • read Google service configuration
    • change network connectivity
