BUDS PRO popup keeps coming when buds slightly move inside the ear via OnePlus 8T
  1. AmalManoj.me
    Cupcake Sep 18, 2021
  2. Harsh PB
    Cupcake Sep 20, 2021
  3. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 20, 2021
    Liehjan , Sep 20, 2021 :
    Try to disable in ear detection and see if it helps?
  4. Harsh PB
  5. AmalManoj.me
    AmalManoj.me , via OnePlus 8T , Sep 20, 2021 :
    Tried disabling in ear detection, still facing the same issue. Tried resetting the buds, still facing the same issue
  6. Liehjan
    What's the firmware version?
  7. AmalManoj.me
  8. Gor.
    Lollipop Sep 27, 2021
    Gor. , Sep 27, 2021 :
    Hey there.
    He was most likely referring to the OnePlus Buds app version. You can check that by going to the Settings app, Apps & notifications, see all apps, look for OnePlus Buds somewhere at the bottom and tap on it, Advanced, scroll down completely and you should be able to see version 1.3.6.
    If you don't have this version then kindly update the app through Play Store:
    https://play.google.com/store/apps/details?id=com.oneplus.twspods&hl=en&gl=US
  9. AmalManoj.me
    Cupcake Sep 27, 2021
    AmalManoj.me , via OnePlus 8T , Sep 27, 2021 :
    I've the latest version. And I'm still facing the same issue
  10. Gor.
    Oh okay. Kindly try this, forget the OnePlus Buds Pro under devices, clear the app cache and reboot.
    If that too doesn't help then try uninstalling updates for the OnePlus Buds app, reboot and then update the app.
  11. AmalManoj.me
    I tried all this bro, I tried forgetting the device and hard resetting the buds pro, reboot device. Uninstall and reinstall OnePlus buds app, everything. It's just keeps on coming. And it's very irritating.
  12. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 27, 2021
  13. AlienEye
    OnePlus Accessory Tester Sep 28, 2021
    AlienEye , Sep 28, 2021 :
    It's an issue with OnePlus Buds application. Are you using beta version? Because man are facing the same issue with beta verision of OnePlus Buds pro app
