Bug report- play store does not load in mobile data via OnePlus 8T
  1. TheMittalUT
    Gingerbread Nov 29, 2021
    TheMittalUT , via OnePlus 8T , Nov 29, 2021 :
    Dear team,
    The play store does not seems ro work with mobile data(4G) . Play Games does load, but the download does not start.
    But play store does not load .. so downloading application using mobile data is out of option😅.
    I tries using different carrier providers but the issue is still there.
    If i try the same sim in different Mobile and connect mu wifi to that phones hotspot, the play store loads and i can download the app as well.
    But again, play store is inaccessible using mobile data.
  2. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 3, 2021
    Best Answer
    Caomhin , via OnePlus 9 Pro , Dec 3, 2021 :
    Just checking if you have set all 3 options in Playstore settings here to Over Any Network.?
    TheMittalUT and puccellino like this.
  3. eddro223
    Cupcake Nov 29, 2021
    pkg3107 likes this.
  4. puccellino
    Lollipop Nov 29, 2021
  5. Caomhin
    9 Series Expert, Participator of the Year Community Expert Nov 30, 2021
    Caomhin , via OnePlus 9 Pro , Nov 30, 2021 :
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions for all your Apps again.
    Check if this can help.
    pkg3107 likes this.
  6. TheMittalUT
    Gingerbread Dec 3, 2021
  7. TheMittalUT
  8. TheMittalUT
    Caomhin and puccellino like this.
  9. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 4, 2021
