6
Bug: Screen turns off during incoming call after receiving
  1. Harpreet541999
    Gingerbread May 22, 2019
    Harpreet541999 , May 22, 2019 :
    Indian OnePlus 7 pro with model no. GM1911 and os version 9.5.3.GM21AA has this bug when there is a incoming call and it is received, the screen turns off even if the phone is not near the ear. The screen refuses to turn on unless the power key is pressed once. This happens each and every time when I receive calls and it is quite cumbersome because I need to put my phone on speaker mode and here the screen is off. Please fix this bug in the latest update. There needs to be some fine tuning done with the proximity sensor.
  2. Harpreet541999
    Gingerbread May 23, 2019
  3. Harpreet541999
    N1563878086112 likes this.
  4. cbrvnm
    Donut May 23, 2019
    cbrvnm , May 23, 2019 :
    I also have this happen at times. And it does get annoying after a while.
  5. Harpreet541999
    Gingerbread May 25, 2019
  6. mindplayintricks
    Donut May 25, 2019
  7. harishhmh
    Cupcake Jul 20, 2019
    N1563878086112 and Amlan@Ch like this.
  8. mrpacs
    Honeycomb Jul 20, 2019
  9. Gupts007
    Froyo Jul 21, 2019
    Gupts007 , Jul 21, 2019 :
    Facing the same issue myself. even tapping on the phone doesn't light up the display. only the power button brings it to life
  10. Gupts007
    Froyo Jul 24, 2019
    Gupts007 , Jul 24, 2019 :
    surely it is not a feature..ok when you put it on the way the screen goes off as proximity sensor triggers that but when you take it off your ear and touch the screen it should light up.. now it only does that when one presses the power button
  11. igen
    Gingerbread Jul 24, 2019
    igen , Jul 24, 2019 :
    I dont think there is a proximity sensor on OP7 or Pro, they use a software based sensor for this.
  12. Abhishikth Gathada
    Cupcake Nov 5, 2019
  13. #13
  14. K1577305319974
    Cupcake Mar 31, 2020
    K1577305319974 , Mar 31, 2020 :
    me, also when I reproduce a file audio from WhatsApp
  15. kuldip3108
    Cupcake Apr 1, 2020
  16. kuldip3108
    Cupcake Apr 1, 2020
  17. Aakura
    Eclair Apr 2, 2020
  18. AZAF786
    Cupcake May 6, 2020
    AZAF786 , May 6, 2020 :
    I am having the same issue. Its so annoying please fix it. I am using OnePlus 7 pro. It happens even on WhatsApp voice messages the screen would turn on and off depending on different angles i don't know whats happening but whatever it is it is very annoying and should be fixed asap.
    M1597931630490 likes this.
  19. M1597931630490
    Cupcake Aug 22, 2020
  20. N1563878086112
    Donut Sep 11, 2020
    N1563878086112 , Sep 11, 2020 :
    can you please explain how it is not bug. if the screen is taken near ear, it should turn off. but holding on your palm and speaker is on and then screen goes off.
    yashvidrohi likes this.
