Bug snapchat
  1. venky1+1
    Honeycomb Oct 29, 2015
    venky1+1 , Oct 29, 2015 :
    Anyone facing this bug
    Any fix for it?
    Please help
    The navigation bar blocks
    henryfelton likes this.
  2. Adam Krisko
    NA Community Consultant Staff Member Oct 29, 2015
  3. AaRe32
    Froyo Oct 29, 2015
  4. venky1+1
  5. anjemalo86
    Cupcake Jan 26, 2016
    anjemalo86 , Jan 26, 2016 :
    I've got the last version of oxygen Os but still facing the same problem. Any solutions?
  6. kill3r_tadej
    Froyo Jan 26, 2016
  7. zsoon
    Cupcake Nov 29, 2016
    zsoon , Nov 29, 2016 :
    Yes I have the same issue on my OP3T. The only way for the snapchat buttons to display above the on-screen is to start a conversation with someone so that my keyboard will pop up. Which makes the snapchat buttons move up above my on screen navigation buttons. Current on OOS 3.5.3
  8. zsoon
    Here is my screen.
    Andi_T likes this.
  9. zsoon
    Doesn't seem like a legit fix but a work around. Some people like on-screen buttons!
    eshaanabhyankar likes this.
  10. F_Scott_Breach_UGUi
    Cupcake Dec 19, 2016
  11. viraaj11
    Community Veteran Dec 20, 2016
    viraaj11 , Dec 20, 2016 :
    Hey if you're on the latest OOS build it should work fine. Here's a screenshot for reference Screenshot_20161220-135715.png
  12. wasdey
    Donut Dec 22, 2016
    wasdey , Dec 22, 2016 :
    facing same problem and i am on the latest build..uhhhh hate this thing
    Andi_T likes this.
  13. zsoon
    Cupcake Jan 2, 2017
    zsoon , Jan 2, 2017 :
    wtf how did you get it to work? What phone are you using?
  14. dipta.ds
    Honeycomb Jan 2, 2017
    dipta.ds , Jan 2, 2017 :
    Where were you? This issue was resolved long back
  15. zsoon
    Cupcake Jan 2, 2017
    The issue still presents on my phone :'( I never had it on my OP3 but when I got the OP3T the problem was there.
  16. dipta.ds
    This is the OP2 forum, so I think you are more likely to get a solution if you search or share your problem in the OP3T forum.
  17. zsoon
    Cupcake Jan 2, 2017
    Ah my bad. I just searched for snapchat and it brought me here. Thanks.
