3
(BUG) White screen Flashes on low brightness
  1. ashj96 Donut Dec 6, 2018
    ashj96, Dec 6, 2018 :
    I am having very bright sudden screen flashes whenever I put my brightness at low setting. The screen just starts flashing and flickering. It works normally when at half brightness. Can anyone tell if they are experiencing anything similar. The flashes are very bright white and the same happens during locking the phone, the screen does not turn off smoothly, it flickers and flashes a bit at the top.
  2. Sharry7 Honeycomb Dec 6, 2018
  3. G_Shahar_Simcomi_TtQw Cupcake Dec 31, 2018
  4. Sharry7 Honeycomb Dec 31, 2018
  5. ashj96 Donut Jan 1, 2019
    ashj96, Jan 1, 2019 :
    **Update on the situation if anyone was wondering**
    It is a hardware issue, I got my display replaced at an authorized OnePlus service center. Everything was done without any issues and now the display is better than ever. So anyone else facing the issue should immediately go and get it checked at your closest service center. Take your phone invoice with you as proof of purchase.
    Sharry7 likes this.
  6. Sharry7 Honeycomb Jan 1, 2019
    Sharry7, Jan 1, 2019 :
    Great!
  7. Sharry7 Honeycomb Jan 1, 2019
    BTW how much time did they need to replace the display?
  8. ashj96 Donut Jan 1, 2019
    I gave my phone on Sunday morning and got it the next day in the morning. So yeah pretty fast I would say.
    Sharry7 likes this.
  9. riggsm Cupcake Jan 30, 2019
    riggsm, Jan 30, 2019 :
    Hey guys! I have found a way that eliminates the screen flickering in low brightness.
    What I did was uninstall the updates for One Plus Launcher, and reinstall it. Then I restarted my phone.
    It has been a few days and I don't experience any screen flickering. Hope this helps!
