11
Bugs in Oxygen OS 4.0
  1. GDurgadas
    Gingerbread Jan 2, 2017
  2. Darkmatter2000
    Honeycomb Jan 2, 2017
    Darkmatter2000 , Jan 2, 2017 :
    I have an issue with the fingerprint unlocking. Sometimes it works instantly, but often it breifly (fraction of a second) seems to display a different screen before unlocking to the correct one.
    It's nothing major, but just looks a bit naff.
  3. Senteznez
    Donut Jan 2, 2017
  4. F_Tanmay_Å_Rawat_lkae
    Cupcake Jan 2, 2017
    F_Tanmay_Å_Rawat_lkae , Jan 2, 2017 :
    True mate.....even I am having the same issue......can't download or update my apps......
    F_Satish_Chandra_EcaU likes this.
  5. Alexander111
    Froyo Jan 2, 2017
    Alexander111 , Jan 2, 2017 :
    Yes, as fast
  6. varungupta36
    Cupcake Jan 2, 2017
    varungupta36 , Jan 2, 2017 :
    I am facing problem with downloading and updating apps through play store. It's not working.
  7. F_Milap_MIna_oRDm
    Cupcake Jan 2, 2017
    F_Milap_MIna_oRDm , Jan 2, 2017 :
    you were the proximity sensor is not working properly sometimes...fix these bugs please....you were good we know that but kindly fix these bugs.
  8. dark.droid493
    Donut Jan 2, 2017
  9. HUSAINtk
    Froyo Jan 2, 2017
    HUSAINtk , Jan 2, 2017 :
    Nop i dont
  10. F_Tanmay_Å_Rawat_lkae
    Cupcake Jan 2, 2017
  11. F_Milap_MIna_oRDm
    Cupcake Jan 2, 2017
    play store installing apps problem...
    fingerprint sensor work late...
    data connection problem...
    proximity sensor problem...
    please fix these problems....
    please
  12. SachinTS
    SachinTS , Jan 2, 2017 :
    Have you faced the accent color issues
    example if you choose blue accent color then opening gallery there will be a different color it is too annoying......
  13. dark.droid493
    Donut Jan 2, 2017
    dark.droid493 , Jan 2, 2017 :
    Now they will take a good amount of time to fix it.
    F_Chetan_Singh_IBhO likes this.
  14. F_Tanmay_Å_Rawat_lkae
    Cupcake Jan 2, 2017
    Bro just factory reset your phone....It resolved the issue for me.....cheers
  15. ghostofcain
    Marshmallow Jan 2, 2017
    ghostofcain , Jan 2, 2017 :
    Care to share the other bugs, you've mentioned one! What are the other many bugs.
    Alert slider will.
    As above.
    This is a nougat problem affecting some users, this needs fixing by Google. IMHO they'd have been better holding back till it was fixed, but the whole "OnePlus are breaking their promise by not giving me nougat now“ brigade made that impossible.
    mkernbach likes this.
  16. Topper_Gas
    KitKat Jan 2, 2017
    Topper_Gas , Jan 2, 2017 :
    Why do posters ask OP to fix this bug and that bug when it seems likely just a problem with their own phones not most users phones, which will most likely be fixed by a full wipe of the handset. OP are only likely to act if a number of users report the same problems/it's not a Google problem anyway.
  17. varungupta36
    Cupcake Jan 3, 2017
    varungupta36 , Jan 3, 2017 :
    Facing same play store problem. Not able to download or update apps. This is really irritating. They have released the update just for the heck of it. Need to fixed immediately.
  18. reaper69ex
    Cupcake Jan 3, 2017
    reaper69ex , Jan 3, 2017 :
    This Is quite Weird I Am Running Oxygen OS 4 on my oneplus 3 with root and Accent H2o2 mod and i've encountered non of the problems in my device i'd recommending you guys do a factory reset and try or take it to a oneplus store as this is pretty un ussual i have a fast response to the Fingerprint scanner, the proximity works fine as it should and the camera still works the best no signal issue either
    #38
  19. Mayur_Gawde
    Cupcake Jan 3, 2017
    Mayur_Gawde , Jan 3, 2017 :
    Yes #2 issue is there and not all the time. There is one more issue,backgroud apps getting forced closed like light flow, walnut,internet speed meter freezes then closed
    #39
  20. paresh rox
    Froyo Jan 3, 2017
    #40
