11
Bugs in Oxygen OS 4.0
  1. G_The_Sarcastic_Devil_jY
    Cupcake Jan 6, 2017
    G_The_Sarcastic_Devil_jY , Jan 6, 2017 :
    My OP3 screen often stops working. It shuts down but the button & sensor, even the sounds keep working.
    After a few minutes the phone restarts by itself & then it becomes normal again.
    anyone else facing this? this never happened before Nougat update.
  2. babelsquirrel
    Froyo Jan 6, 2017
    babelsquirrel , Jan 6, 2017 :
    The interesting thing about the intermittent sensor problem is that, as far as I can tell, it only happens with regular PSTN voice calls. The screen turns off reliably when making whatsapp calls or hangouts dialer voip calls.
  3. HUSAINtk
    Froyo Jan 7, 2017
    HUSAINtk , Jan 7, 2017 :
    Oxygen OS 4.0.1 has been updated in OP3 that fixes #1 problem
  4. G_Shiva_Padmanaban_kdBd
    Donut Jan 7, 2017
  5. uvaish8248
    Froyo Jan 7, 2017
    uvaish8248 , Jan 7, 2017 :
    I'm also having 1st issue.
    and 2nd is whenever I closes music app and opens it again I need to turn on set shuffle and repeat everytime. It's like every time app restores automatically.
  6. G_Alejo_HiGuera_MXNF
    Gingerbread Jan 7, 2017
  7. shahidsayyed
    Cupcake Jan 7, 2017
    shahidsayyed , Jan 7, 2017 :
    I have same problem
  8. HUSAINtk
    Froyo Jan 7, 2017
    I had problem of downloading and updating apps from playstore but now it is automatically fixed playstore bug is gone.
  9. G_Alejo_HiGuera_MXNF
  10. HUSAINtk
    Froyo Jan 7, 2017
    did you reset after update?
  11. Arshnoortandon
    Donut Jan 7, 2017
  12. arora496
    Cupcake Jan 7, 2017
    arora496 , Jan 7, 2017 :
    1. I can't share pictures from Facebook to other apps like WhatsApp , hike etc. After upgrade.
    2. Some of the apps are automatically killed from the background process and thus notifications are not received for them
    3. Notifications get cleared automatically without being noticed
    4. Fingerprint unlock takes longer than before. (there's is a minute difference)
    5. Can't uninstall some apps like Duo after upgrade
    6. Bluetooth devices get unpaired on their own and gets disconnected when not used for some time
    7. Unable to download applications from play store some of the time and then if you restart the device it gets fixed
    If there are any other issues observed. I'll update them in this thread only.
    Thanks
    G_Simar_Johar_JkvL likes this.
  13. G_Alejo_HiGuera_MXNF
  14. G_Tika_Ram_Dahal_jIkY
    Cupcake Jan 7, 2017
    arora496 likes this.
  15. F_Prem_Biradar_yNan
    Cupcake Jan 7, 2017
  16. Ravipras
    Donut Jan 7, 2017
    Ravipras , Jan 7, 2017 :
    found below issues on nougat update. don't know what tested even in beta testing
    -2 calculators. New one with no menu
    -While adding caption to WhatsApp image on uploading keyboard will cover the caption. We can't see what we typing
    -On normal music player play some song and in Google play music play same song now go back to another music player n play the music player will stuck
    -2 apps for SMS
    -play some song through files with normal music player and try to pause, it won't work
  17. G_Don_Mario_FAyL
    Cupcake Jan 7, 2017
  18. victorzerk
    Cupcake Jan 7, 2017
  19. ghostofcain
    Marshmallow Jan 7, 2017
    ghostofcain , Jan 7, 2017 :
    Possibly a permissions issue, although do note not all apps are nougat compatible at this time.
    Try disabling aggressive doze or. Whitelisting apps.
    Again probably a doze issue
    Removing and re-entering the fingerprints may help as may a cache wipe
    Yes I know added bloat, although I believe Google may be to blame here, one of the reasons i rooted, they can be disabled though without root.
    Not seen this mentioned maybe a doze issue?
    Now this does sound like a cache issue.
    You might want to read OP before commenting a factory reset will not fix all his quibbles.
  20. victorzerk
    Cupcake Jan 7, 2017
    victorzerk , Jan 7, 2017 :
    is it mandatory or recomended to clear cache before Factory reset?
