bullet wireless slow charge
  1. mburns2
    Eclair Jul 14, 2018
    mburns2 , Jul 14, 2018 :
    Hi all
    I cannot use the bullet if they are not fully charged.
    For example: i i recharge them for 15 minute and i try to turn them on, they show a red light and i cannot use them. Is this normal ?
    Thanks
  2. hotmomma
    Ice Cream Sandwich Jul 14, 2018
    hotmomma , Jul 14, 2018 :
    according to OP it sure isn't, but are you certain of the issues you mentioned and you using the accessories provided with the bullets wireless?
    mburns2 likes this.
  3. Moin2200
    KitKat Jul 14, 2018
    Moin2200 , Jul 14, 2018 :
    The red light indicates low battery, did you use the cable provided with the bullets?
    If so I recommend opening a ticket right away.
    mburns2 likes this.
  4. mburns2
    Eclair Jul 14, 2018
    can i use op6 cable and charger ? i even tried to use the cable provided with it..
    Now they are charging since 30 minutes and i still cannot use them..for me isn't normal, even after unboxing they were without any charge inside it..
    update: i charged them for more than 1 hour with the stock cable and i still cannot turn them on..
    update 2: I opened a ticket for a replacement because they are still red even after hours of charge..
  5. hotmomma
    Yeah, you should contact OP you must have received a damaged unit.
    mburns2 likes this.
  6. M1527242896501
    Cupcake Jul 15, 2018
    M1527242896501 , Jul 15, 2018 :
    I have a similar situation.) Please let me know how your question was resolved.
  7. HeadElastico
    Froyo Jul 15, 2018
    HeadElastico , Jul 15, 2018 :
    Quick question - what charger do you use with the earphones? I mean, you use the cable with what charger? The OP6 charger? Can we just use the OP6 charger and cable?
  8. mburns2
    Eclair Jul 15, 2018
    mburns2 , Jul 15, 2018 :
    nothing to do, i opened a ticke. Now i cannot turn them on..
    i have always used the stock cable, i tried to charge it with op6 charger and with others charger..
