9
Bullet wireless z mic not working via OnePlus 5T
  1. G_swamy_kvvk_Graw , via OnePlus 5T , Jun 6, 2020 :
    hi there,
    i recently bought oneplus Bullet wireless Z earphones, while taking calls they are saying im not audible, i think it had problem with muc. How can i resolve this issue, please help.
  2. KK3498
    Cupcake Jun 12, 2020
    KK3498 , Jun 12, 2020 :
    Same issue with me too. Even voice messages sent on whatsapp through bullets wireless Z mic are inaudible. Please help.
  3. K1593025251140
    Cupcake Jun 25, 2020
    K1593025251140 , Jun 25, 2020 :
    // Same problem here on my side too. I even tried to contact The customer care bit i couldn't get thru dem. Can anyone help on how to proceed further?
    PS: I bought Oneplus bullets wireless z on amazon.in n it's return window too is closed.
  4. V1537885566194
    Cupcake Jul 4, 2020
  5. Moki07
    Cupcake Jul 5, 2020
    Moki07 , Jul 5, 2020 :
    Have the same issue here as well. I have mailed the support team on the same. Waiting to hear from them.
    Zeeshan_Ali and KK3498 like this.
  6. sathyanmoorthy
    Cupcake Jul 5, 2020
  7. Anandhaprawin
    Cupcake Jul 13, 2020
  8. jsmonu
    Donut Jul 13, 2020
    jsmonu , Jul 13, 2020 :
    Exact same frikkin problem here.. Worked fine for a month or so, now suddenly users are reporting inaudible volume over calls.. Tried resetting too, and tested with laptop as well, but SERIOUSLY LOW volume going through the mic.. Tried cleaning via blowing air too, but no result. Anyone face any success in resolving this?
    Or do we just need to raise support issue and try to repair/replace only?
  9. hardik4560
    Cupcake Jul 16, 2020
    hardik4560 , Jul 16, 2020 :
    I have this exact same issue. Just bought them 20 days ago n now this happened. What can be done about this? someone please suggest. The mic is working fine when recording but while calling the other person is not able to hear my voice. If I blow into it than that can be heard by the other person. please help
  10. SathishR15
    Cupcake Jul 21, 2020
    SathishR15 , Jul 21, 2020 :
    I also facing this problem in recent times... can any one help me out
  11. JerryJemson
    Cupcake Jul 23, 2020
    JerryJemson , Jul 23, 2020 :
    Hey guys! I'm too facing this issue...
    It's seems that our phone isn't using the mic from the wireless z and uses its own mic...
    I tried recording my voice through my laptop, mic in wireless z works...
    But when connected to phone, the voice record isn't recording the sound from bullets z but rather uses phone mic...
    It's same with whatsapp and other apps...
    Any solutions?
  12. kvtoraman
    Cupcake Jul 28, 2020
    kvtoraman , Jul 28, 2020 :
    Same problem here. I have OP 7T.
    Whatsapp / Voice record uses phone mic instead of mic from wireless z...
    I will try with my laptop as well.
    Guys, what might be the reasons? I thought my sweat went inside when I run outside but i'm not sure...
  13. W1573301541072
    Cupcake Aug 3, 2020
    W1573301541072 , Aug 3, 2020 :
    Facing the same issue after using 15 days, the other person in the call not able to hear me properly they are telling I'm not audible speak loud. This is happening many times in a couple of days.
    F_Sapeksh_Suman_iRBX likes this.
  14. kvtoraman
    Cupcake Aug 4, 2020
    kvtoraman , Aug 4, 2020 :
    OP Wireless Z should be sweat resistant right? Actually I had the same problem with my previous OP Wireless 2. I used OP wireless around a year and then these problems occured: voice goes up/down, mic doesn't work, unpairs from my phone.
    I bought my OP Wireless Z from **********. But the seller there doesn't reply to my messages. Should I contact with OP Support?
  15. somratpro
    Cupcake Aug 5, 2020
    Zeeshan_Ali likes this.
  16. Abdul Jazim
    Cupcake Aug 7, 2020
    Abdul Jazim , via OnePlus 7 Pro , Aug 7, 2020 :
    I am also facing same issue. While sending voice messages through whatsapp its inaudible. But while calling its normal and working fine. Am usine OP7PRO. Any remedy for this
  17. Dhwanit.Agrawal
    Cupcake Aug 7, 2020
  18. C1594788310619
    Cupcake Aug 24, 2020
    C1594788310619 , via OnePlus Nord , Aug 24, 2020 :
    The headset's mic is not used while recording audio or using for whatsapp call or playing pubg. Is there any way to fix this. please reply, a lot of people are having this same issue.
  19. L1596468215306
    Cupcake Sep 3, 2020
    L1596468215306 , Sep 3, 2020 :
    Have returned or claimed your warranty on that earphones.
  20. C1571331661766
    Cupcake Sep 5, 2020
    C1571331661766 , Sep 5, 2020 :
    i have also purchase the same one plus bullet z from Amazon the same issue is facing with the mic. mic is not working in the calls. as the customer care is not replying do the needul
