3
Bullets 2 wireless
  1. Vimalgamer
    Cupcake May 23, 2019
    Vimalgamer , May 23, 2019 :
    Bullets 2 wireless is lacking in bass..so please give some software update to Increase bass for op7pro....then....
    while playing pupg sound is not syncing..it's too late..for bullets to get the sound
  2. G_Carmelo_Setaro_vLgh
    Cupcake May 29, 2019
    G_Carmelo_Setaro_vLgh , May 29, 2019 :
    I have the same problem. I also have a very loud background noise, which is very annoying.
    Also, it's a bit sobering that there's no factory default equalizer app at the start, so you can customize the sound and update it?
    Normally you should be able to achieve extremely low latency values with aptX hd. Unfortunately the reality is different. These are by far the worst latency values I have ever seen with a Bluetooth headphone. Even the cheapest headphones without Bluetooh 5.0 , without aptX hd get it better.
    OnePlus, please do something quickly, otherwise they will go back!
    I wouldn't recommend the headphones to anyone!
  3. Nick 59
    Marshmallow May 29, 2019
    Nick 59 , May 29, 2019 :
    The community here is made up of Oneplus users, just like you, and we can't give "some software update". Try contacting Oneplus.
    If you have bugs to report : https://forums.oneplus.com/feedback/
    If you want to contact the support team : https://www.oneplus.com/support
    If you want to submit a suggestion : https://forums.oneplus.com/feedback/create?type=2&node_id=314
