Bullets wireless 1- magnet case dismantled.. via OnePlus 5
  1. G_Vels_S_wWrR
    Eclair Feb 20, 2020
    G_Vels_S_wWrR , via OnePlus 5 , Feb 20, 2020 :
    Hi community,
    I have been using my Bullets wireless for past one year and one month.. Now suddenly the magnet inside has come out along with the outer case due to adhesive issues... Care team told its not possible to get it replaced...
    Does anyone have idea to get this sorted?? what glue can be used to stick it back?
    attached is the image for reference..
  2. G_Vels_S_wWrR
    Eclair Feb 22, 2020
    G_Vels_S_wWrR , via OnePlus 5 , Feb 22, 2020 :
    I recommend instant bond ... also I here by caution the community to make sure you stick the magnet in the same direction. I stuck it in opposite directions and had a big headache to remove the bond.( use gel type bond instead of liquid bond) .. however, I lost magnetic play pause off function after this issue. thankfully the headset is working fine for now... something is better than nothing!!!
    if anybody has a solution to fix magnetic play pause issue please do comment
    Starcommander likes this.
