Bullets Wireless 2 on Windows 10
  1. Sebastian Trummer
    Eclair Jul 3, 2019
    Sebastian Trummer , Jul 3, 2019 :
    Hey guys,
    So I bought the Bullets Wireless 2 with my OP 7 Pro and they work great but I would like to use them at my work pc as well since they have a built in microphone and they are so much better than my headset
    Does anyone know how to connect them to a Windows 10 PC? I just can't find them when I am searching for Bluetooth devices
    Thanks
    Sebastian
    jasmeet_sachdeva likes this.
  2. Praty_28
    KitKat Jul 3, 2019
    Praty_28 , Jul 3, 2019 :
    Make sure you disconnect the buds from your 7 pro and then scan for available devices on your pc.
  3. Sebastian Trummer
    Eclair Jul 3, 2019
  4. marcozwetsloot
    Eclair Jul 12, 2019
    marcozwetsloot , Jul 12, 2019 :
    I have same issue....switched off bluetooth on my OP6 and switch on bullets, they don't show up as device on windows laptop. When I connect the buds (bullets switches off) then device OP headset shows in the list but I can't connect. I double pressed the on/off button to make sure it is not connected to any other device but onfortunally that doesn't help.
    To me that is like a more general problem with bluetooth devices which seem not to be able to connect to other devices smoothly whenever they are known on another device. But that was one of the reasons to buy these bullets as it is advertised they can switch easily.
  5. marcozwetsloot
    Eclair Jul 12, 2019
    I got it working....make sure bluetooth is switched off on all devices where the bullets are paired with. Then switch on bluetooth on new device and power on bullets. Then the bullets show up in the bluetooth devices and I was able to pair and connect.
    I then switched on bluetooth on the other paired devices (OP6 and iPad) and I am able to switch between the devices by pressing the power butto twice.
  6. alexshostak
    Cupcake Dec 6, 2019
    alexshostak , Dec 6, 2019 :
    Hello. I have a solution. Firstly, you should connect OP Headset, then connect additionally OnePlus Bullets Wireless 2.
    Here is a screenshot how it's should be:
    [​IMG] [​IMG]
    V1590993333427 likes this.
  7. C1577107305213
    Cupcake Jan 2, 2020
    C1577107305213 , Jan 2, 2020 :
    I have a similar problem, recently bought a Onepluse Bullet Wireless v2. The real issue is OP B v2 is not connected properly with Windows, it shows OP Headset paired, sometimes connected, but I don't see proper naming convention, either way, I don't see sounds properties show OP headset. So how to solve this,
    Note:
    1. I tried pressing the power button for 5 seconds till the headset power LED blinks, still not working
    Any other suggestions for Lenovo based windows?
    P1631946446796 likes this.
  8. mmavcy
    Cupcake Jan 2, 2020
    mmavcy , Jan 2, 2020 :
    1. Switch OFF Bluetooth on the phone.
    2. Switch OFF Bullets by touching the earphone magnets to each other.
    3. Restart the PC.
    4. Open Bluetooth Devices as per screenshot:
    5. Switch ON Bullets by putting the earphones in your ears.
    6. Make them discoverable by long-pressing (~5 seconds) the big circular button at one end of the neck piece.
    7. Search for the device by adding a Bluetooth device on the PC, as per screenshot:
    8. Once connected, you can switch off Bluetooth on the PC as per the screenshot below (...or unpair only the Bullets by opening "Bluetooth & other devices" in Settings), and switch ON Bluetooth (...or pair Bullets) on the phone. And vice versa.
    Liehjan likes this.
  9. matcha manoj
    Cupcake Jan 6, 2020
    matcha manoj , Jan 6, 2020 :
    1. Disconnect from other devices first
    2. Turn on bluetooth from bluetooth & other devices on your pc
    3. Add bluetooth a d other devices and select bluetooth
    4 when its searching connect the ear phone magnets together and remove them
    5. Press and hold the single button on the neck band
    6. It will show up and pair them, after pairing it will be displayed under audio where you have to select connect..
    [e]1f623[/e][e]1f623[/e]It is a long process.. Hope it helps. Also the screens i mentioned can be found in the above comments.. [e]270c[/e]️
    Nacreouse likes this.
  10. Malarsi
    Cupcake Apr 17, 2020
    Malarsi , Apr 17, 2020 :
    Hello,
    I have the same problem. Bullets Wireless 2 had a problem where only playback worked but not the microphone. I tried to disconnect and connect them again but now they can pair but not connect to my laptop. I tried all the fixes, including playing around with Windows services, updating my drivers and such. Even the quick switch is not working properly, needing to press it several times for it to work on other devices. Oddly enough, it works on other devices fine.
  11. sathishsms1
    Cupcake May 14, 2020
  12. Razvan_19
    Donut May 19, 2020
  13. gperez
    Cupcake May 27, 2020
    gperez , May 27, 2020 :
    Windows 10 (OS 18362.836) - No microphone and I've tried all suggestions.
  14. Nacreouse
    Cupcake Jun 7, 2020
  15. n2j
    Cupcake Jun 10, 2020
    n2j , Jun 10, 2020 :
    Hello,
    The mic does not show up in the device list for me in Dell Laptop. Any suggestions on how to get this to work.
    The audio output however works without issues.
  16. ravr
    Eclair Jun 10, 2020
    ravr , via OnePlus 7T , Jun 10, 2020 :
    I had no problem connecting the earphones, although I'd like to know if there's a way to manipulate the sound settings over pc for bluetooth earphones?
    Y1607750618990 likes this.
  17. Infusion64
    Cupcake Jun 16, 2020
    Infusion64 , Jun 16, 2020 :
    Everything is working fine. I have no problems that were described here. But unfortunately I still can't use them because of Windows.
    The thing is i get Bluescreen when I am using them in Windows 10. I don't know, maybe they have buggy audiodrivers... I don't know.
  18. Q1592416152344
    Cupcake Jun 17, 2020
    Q1592416152344 , Jun 17, 2020 :
  19. Q1592416152344
    Try the configuration settings as told by other folks...if then as well you can't able to connect then you have to download a Bluetooth driver ...like I have Thinkpad laptop so I have downloaded the driver from https://support.lenovo.com/in/en/downloads/ds029104 which is ThinkPad Bluetooth with Enhanced Data Rate Software for Windows 7 (32-bit, 64-bit) - ThinkPad...I installed it then I got the option to connect to the Bluetooth device at the start menu... I thin same would work for win 10 or other laptops
  20. sicarius08
    Cupcake Jul 25, 2020
    sicarius08 , Jul 25, 2020 :
    Hi man!
    I am facing an issue with these earphones.. and I can see that the level of microphone on your snapshot is highest and the same case is with me.. when I use these as a mic then only noise comes from the recording and the sound level always shows 80-90% even when I'm in a silent room and I'm not even speaking anything.
    Kindly tell how can I use them as a microphone!
    Thanks!
