Bullets Wireless Problem
  1. Petja Redlin
    Cupcake Jul 1, 2018
    Petja Redlin , Jul 1, 2018 :
    My Bullets have developed a problem, and it's the in-line controlls. Buttons work as intended but they now have this weird shape that wasn't there when new. Does anybody know what is going on? Pls comment if you have this problem. Thx
    wd250r likes this.
  2. wd250r
    Cupcake Jul 18, 2018
    wd250r , Jul 18, 2018 :
    I'm having the same problem with my bullets wireless, have you found any solutions or why its doing that?
  3. sajan.joseph24
    Cupcake Jul 21, 2018
    sajan.joseph24 , Jul 21, 2018 :
    The audio output changes to phone speaker automatically on incoming notifications. Can we hope this to get fixed soon? Oneplus please correct this!
    wd250r likes this.
  4. Petja Redlin
    Cupcake Sep 24, 2018
  5. sweggitity
    Honeycomb Nov 26, 2018
    sweggitity , Nov 26, 2018 :
    It seems to be caused by over charging or by using a powerful charger, i guess the battery is there. Don't use OnePlus charger to charge ur Bullets. Use ur laptop to charge it or any low powered output.
  6. Petja Redlin
    Cupcake Nov 26, 2018
    Petja Redlin , Nov 26, 2018 :
    Isn't the battery on the neck part, that is really light and small for a battery + the buttons work
  7. GopalB.
    Nougat Nov 26, 2018
    GopalB. , Nov 26, 2018 :
    Battery is on the neck band AFAIK...
  8. vsrivastva9
    Froyo Dec 19, 2018
    vsrivastva9 , Dec 19, 2018 :
    My bullets keep on disconnecting and getting off on their own. 4k bucks ep behaving like this.
  9. Sujknair
    Ice Cream Sandwich Dec 19, 2018
    Sujknair , Dec 19, 2018 :
    Im no expert, but it looks like rubber thats lost its elasticity, maybe? I dont own one but are the buttons rubber?
  10. Nikkhil
    Jelly Bean Dec 19, 2018
  11. Petja Redlin
    Cupcake Dec 19, 2018
    Petja Redlin , Dec 19, 2018 :
    I have not abused them at all. i even got a second pair and it did the same thing. I think its a quality problem
  12. neodyymi
    Eclair Jan 9, 2019
    neodyymi , Jan 9, 2019 :
    I have this same exact issue. Have you tried contacting Oneplus about this?
  13. Petja Redlin
    Cupcake Jan 23, 2019
    wd250r likes this.
  14. Edvins Jursens
    Edvins Jursens , Jan 23, 2019 :
    I was planning to buy them only the red version, but somehow it scared me that suddenly I would have a similar problem.
  15. Petja Redlin
    Cupcake May 1, 2019
    Petja Redlin , May 1, 2019 :
    Update: I got third ones from warranty, cause audio stopped working on the other ear, but now my new ones broke too(only one ear working), im wondering if they will give me a fourth pair? Use your ones extra nicely, thease are brittle af.
  16. rakesh1809
    Cupcake Aug 3, 2019
  17. loco-cork
    Gingerbread Sep 14, 2019
    loco-cork , Sep 14, 2019 :
    Mine are gone exactly the same. Even though I used them very carefully and not too often. Must be poor quality material used. Will try RMA tomorrow.
