3
Bullets Wireless Volume Control Issue
  1. Sydeon
    Cupcake Oct 31, 2018
    Sydeon , Oct 31, 2018 :
    Previously it worked fine, but recently I've noticed that the Bullets Wireless now seem to have their own separate internal volume and it no longer controls the phone's bluetooth volume, so even when using the Bullets Wireless I still have to use the volume rocker on the phone itself to effectively change the volume.
    I've tried forgetting and re-pairing it, fiddling with various settings, and of course restarting the phone.
    It's paired with a red OP6 8GB, not rooted and with the latest updates installed on the stable release channel. In case it's an issue of conflicting devices, the phone is also usually paired to a Huawei Watch 2.
  2. G_Mattia_Barbon_lsej
    Gingerbread Nov 22, 2018
    Akeel_Ramzan likes this.
  3. G_Mattia_Barbon_lsej
    G_Mattia_Barbon_lsej , Nov 22, 2018 :
    I've just disconnected them and reconnected by using magnetic control and now volumes are synchronised. I don't know, maybe it's something they can solve with an update.
  4. kort
    Cupcake Nov 23, 2018
    kort , Nov 23, 2018 :
    I have the same issue, I tried unpairing them as well as reseting them and it worked once but as soon as I turned my screen off it went back to having its separate volume...
  5. javibelando
    Cupcake Dec 7, 2018
    javibelando , Dec 7, 2018 :
    Same here. I think the volume of the wireless bullets got independent with the update to android 9 Pie, because before it was synchronized with the bluetooth volume. Please Oneplus fix it!
  6. sanketh_br
    Eclair Dec 8, 2018
  7. sanketh_br
    Eclair Dec 8, 2018
    1plus_batman likes this.
  8. Julybil
    Cupcake Dec 10, 2018
    Julybil , Dec 10, 2018 :
    I am having the same issue. It started occuring weeks ago, but I have not manage to fix it in the meantime.
  9. King_Casual
    Donut Dec 17, 2018
  10. sanketh_br
    Eclair Dec 17, 2018
  11. Akeel_Ramzan
    Cupcake Dec 22, 2018
  12. Julybil
    Cupcake Jan 10, 2019
    Julybil , Jan 10, 2019 :
    I have fixed this problem on my OnePlus 6. Try to forget the bullets wireless first, then pair it again. The next thing is to disable all features with the sliders and then enable them all back again. I think the problem was do to the media share slider, because when you disable that feature via the slider and enable it again the Qualcomm aptx slider shows up. Enabling this feature with the popped up slider fixed the problem for me.
  13. vincent275
    Cupcake Jan 20, 2019
    vincent275 , Jan 20, 2019 :
    I am having this problem as well, with multiple different bluetooth headphones. The inline control seem to control the internal volume of the headphone while the phone's volume buttons control the device volume. It is not the headphone's problem. I have a pixel 3 and they are work just fine on the pixel.
    Device is Oneplus 6t, software version 9.0,11
  14. scrushox
    Cupcake Feb 23, 2019
    scrushox , Feb 23, 2019 :
    I dont know wich slider solved the problem but it worked like you described. Thank you
  15. gautamkrishnar
    Eclair Apr 6, 2019
    gautamkrishnar , Apr 6, 2019 :
    I am having this problem now... I tried everything nothing works...:( Oneplus please fix this bug ASAP...
  16. G_Jacques_Bercion_IXxI
    Cupcake Apr 7, 2019
    G_Jacques_Bercion_IXxI , Apr 7, 2019 :
    Hello,
    I'm writing here today because i need to find a solution about an issue. I've got the oneplus wireless bullets, there are perfect, I use it everyday etc but.. there is a led (near the power button) that makes light every 3-4 seconds ... it doesn't bother me when I use it on the day, but when I'm using it in bed, with no lights on, it clearly bothers me...
    Do you guys know how to disable this led ?
    I have to post it in an existing thread cuz I can't create one ...
  17. Julybil
    Cupcake Apr 7, 2019
    Julybil , Apr 7, 2019 :
    I have the same issue with the white led. I don't know what it is supposed to indicate, but this white led would be more helpful if it only lighted up once when the device is paired and not even 3 to 4 seconds.
  18. Srinoj
    Cupcake Apr 18, 2019
    Srinoj , Apr 18, 2019 :
    Dear All, The volume controls on the earphones are separate from media volume on the phone. so increase volume of bullets wireless and check. Though the we have enabled auto sync volume, still the volume can be controlled individually from both the phone and bullets wireless. So try this...
  19. G_Adam_Matthew_Blakey_wL
    Cupcake May 3, 2019
  20. Starcommander
    Lollipop May 3, 2019
    Starcommander , May 3, 2019 :
    I know this issue. I have received acknowledgment from bughunters. They are working on it. Fix will be provided in next update hopefully
