41
Accessories Bullets Wireless -Z The Review and Comparison
  1. karu12061997
    Cupcake Jun 9, 2020
    karu12061997 , Jun 9, 2020 :
    Hey I would like to know which charger you're using cause with my warp charger it takes around 50 minutes for full charge
    #41
    Helder_DAlmeida and Dresa91 like this.
  2. Batman360
    OnePlus Accessory Tester Jun 9, 2020
    Batman360 , Jun 9, 2020 :
    Warp charge 30.
    Are you using the original charging cable?
    #42
    SRD., Helder_DAlmeida and Dresa91 like this.
  3. karu12061997
    Cupcake Jun 9, 2020
    karu12061997 , via OnePlus 7T , Jun 9, 2020 :
    Yes I am , I tried the original cable , it took 56 minutes , will resetting the earphones do any good?
    #43
    Helder_DAlmeida likes this.
  4. Batman360
    Yes try factory resetting the earphones
    #44
  5. #45
    SRD. and Batman360 like this.
  6. Batman360
    OnePlus Accessory Tester Jun 11, 2020
    Batman360 , Jun 11, 2020 :
    You're welcome Prasanna 😉 Don't forget to share your experience of using BW-Z 😊
    #46
  7. Prasannabalaji1402
    Donut Jun 12, 2020
    Prasannabalaji1402 , Jun 12, 2020 :
    hey, I just received my BMZ today and writing the post enjoying good music with it.
    I even tried with the games and, even a bit of bass-heavy songs. I'm not an audiophile, but the cons that I see on other forums or posts don't kinda exist. It's good with games and its good with songs and also it feels really comfortable on my ears. :D
    #47
    luxuskamel and Batman360 like this.
  8. Batman360
    OnePlus Accessory Tester Jun 12, 2020
    Batman360 , Jun 12, 2020 :
    Glad to know you are enjoying it buddy😄😄
    #48
  9. Elatchian Veeramani
    Honeycomb Jun 12, 2020
    Elatchian Veeramani , via OnePlus 6 , Jun 12, 2020 :
    Review after 10 Days of Usage :
    1.Usage: I Would Say BWZ was preferably made for Op devices especially from Op7 series. The reason behind that was The difference b/w HD AAC and Dolby Atmos* which is supported from op 7+ series only. That will give u the Exact Sound Tune and Quality they made using Single 9.12mm driver.
    2. Connectivity: Tooks 2-3 secs for me to pair with my Op6.
    3. Sound Quality: Average. I would say Clarity is there but not the quality. Don't expect More for this price Range.
    4. Buttons: Quite sticky. Doesn't felt that click.
    5. Battery Backup: Same as expected the battery backup is excellent. But I would like to note a point: BWZ Battery Consumption is directly proportional to the Distance of the BWZ from mobile. If u are at the verge of 10-12 mtrs surely battery will last within 2-3hrs from 100% charge. I have tested this twice.
    6. Design and Make : Excellent Design. Cables are smooth and Strong.
    7. Charging: As scripted 10 mins of charge will surely give u 10hrs of backup. it took 30 mins to fully charge using my Op6 dash charger.
    #49
    roshanu likes this.
  10. X1576257783015
    Cupcake Jun 19, 2020
    X1576257783015 , Jun 19, 2020 :
    I am unable to use my oneplus bullets z on my PC as a normal headphone and mic. There are two connection settings stereo and handsfree, to use mic I have to turn on handsfree which has very bad really audio output quality.
    #50
  11. prakash913
    Cupcake Jun 28, 2020
  12. Batman360
    OnePlus Accessory Tester Jun 29, 2020
    Batman360 , Jun 29, 2020 :
    That was some very thorough testing you did there!! Kudos! 😊
    Pc or laptop??
    #52
  13. X1576257783015
    Cupcake Jun 29, 2020
    X1576257783015 , Jun 29, 2020 :
    PC with Bluetooth adapter
    #53
  14. Batman360
    Don't know about this tbh. I have a laptop and BW-Z works fine with it.
    You got a different setting with the bluetooth adapter. I recommend you to contact the customer care for this.
    #54
  15. X1576257783015
    Have you tried using mic together with the audio like online gaming?
    #55
  16. Batman360
    Yes and it works perfectly fine.
    #56
  17. X1576257783015
    #57
  18. luxuskamel
    Marshmallow Jun 30, 2020
    luxuskamel , Jun 30, 2020 :
    I got the BWZ too and gave my BW1 to my sister :)
    Therefore i can't directly compare, but I think the BW1 had more sound spectrum while the BWZ have a bit more bass. Idk hard to compare
    #58
    Batman360 likes this.
  19. luxuskamel
    unboxing pleasure more like 6-7
    The ear plugs just all stuffed in a plastic bag, the cable came as a knot. It doesn't feel super premium as the BW1 did
    First of all thanks for explaining the buttons. Didn't know about the hold to adjust volume, triple click PP.
    I find the buttons harder to use especially when wearing gloves, idk maybe because the remote is bigger(?)
    Not sure if that would be your hardware or your button rating. I would give it 7
    #59
  20. Batman360
    OnePlus Accessory Tester Jun 30, 2020
    Batman360 , Jun 30, 2020 :
    Congratulations for the new BW-Z 😎🔥 BW-Z indeed has more bass, does its job as advertised 😉
    Thanks for your thoughts 😊🤗 Fir me the packaging was subtle I liked it 😊
    And you're welcome😊 I don't usually use buttons but they come in handy whenever needed 😄
    #60
    Helder_DAlmeida and luxuskamel like this.
