2
Bumper case scuffed my phone... :(
  1. cooki3sanyday
    Jelly Bean Oct 31, 2014
    cooki3sanyday , Oct 31, 2014 :
    As the title says, it scuffed my phone. It was a metal bumper for like 8 bucks or so, and cut into the sandstone backing. It left a mark; black plastic underneath the sandstone texture, and the sandstone is very white and can peel easily. The mark is like 1 inch long, 1mm wide. Not too big of a cut / scratch. I'm hella pissed though since I took great care of the phone, and it ended up being ****** over by a case I bought... Counter-productive... I thought the bumper case would be a good buy (though, could be just this one). Has this happened to other people? Can't be assed to take pics though lol.
    Peanutbrain and Bi I like this.
  2. deameong
    Cupcake Oct 31, 2014
  3. carbine30
    Marshmallow Oct 31, 2014
    carbine30 , Oct 31, 2014 :
    always get original accessories :) it has been tested so it won't corrupt your phone .
  4. chongswee
    chongswee , Oct 31, 2014 :
    sorry for that, mind to share the picture?
    By the way, can order the back cover form China web.
  5. shadowX159
    Ice Cream Sandwich Oct 31, 2014
    shadowX159 , Oct 31, 2014 :
    Sure, if you want to destroy the purpose of having a unique back by covering it...
    ... oh, it won't matter because they stop SwapStyle covers, so I guess it's all good :/
  6. MrSober88
    Froyo Oct 31, 2014
    MrSober88 , Oct 31, 2014 :
    Just order a replacement from China heaps of them floating around, and they are the real deal not fakes. But just make sure its a real one!
  7. carbine30
    The transparent will be good choice :)
  8. cooki3sanyday
    I already ordered a normal case (pelosi sandstone one). As for the bumper case, I don't think I'll be buying another...
    Bo_Floyd and Bi I like this.
  9. MrSober88
    Froyo Oct 31, 2014
    You do get that though, I bought a Logitech case for my work iPad that has a keyboard. The Keyboard has scratched the screen. It is the risk you have to take I guess when buying a case that is not from the company that make the product. But if a big company like Logitech can get it wrong then I guess anyone can.
  10. Bi I
  11. ethanchim10
    ethanchim10 , Oct 31, 2014 :
    that sucks....
    i bought an aluminium bumper, and when i install it, i regret it almost immediately.....
    i changed back to my Diztronic after 2 days.....
    anyway, the back cover is actually replaceable.....just search for it, you should be able to find it.....
  12. cooki3sanyday
    True. I heard the official OnePlus cases aren't any good though. The bumper case was metal, but my newer case isn't I'm hoping it won't scratch it or anything. For the screen I have a screen protector, so I'm fine with the protector getting scuffed.
  13. cooki3sanyday
    It was going to be, but they cancelled the swap style backing.
  14. ethanchim10
    there are the Sandstone back cover up for sale as well....
  15. MrSober88
    Froyo Oct 31, 2014
    I would have no idea about their cases, but they could easily get it wrong also. Even Apple cases have had issues but by buying it from them you would have a chance to get the phone fixed free as their product is what damaged it.
  16. cooki3sanyday
    The back cover is the same as the swap style cover. Originally they were going to make them, but I'm pretty sure only a limited supply will go on sale. I don't think I'm getting it though/
  17. cooki3sanyday
    Still, I heard that the cases were bad, not that it damaged the phone (sorry, didn't specify this). Apparently they can crack easily, even from normal use / not dropping it. Fair point, for the second part.
  18. Freshman117
    Honeycomb Oct 31, 2014
    Freshman117 , Oct 31, 2014 :
    Which bumper did you use? and You can contact the support to buy a new sandstone black backcover
  19. MrSober88
    Froyo Oct 31, 2014
    Sorry my bad, But yes I have also heard the build quality of the OP cases are not really up to scratch.
  20. Pablo1986
