Burned battery and motherboard
  1. claudiumarius Froyo Aug 15, 2019
    claudiumarius, Aug 15, 2019 :
    I left my OP3 to charge OVERNIGHT, original charger and cable. As a result the battery and motherboard burned. What would be the cause? Battery, cable, charging socket, short circuit? I just get an oneplus 7, could I use the old charger or might be a problem?
  2. Horsault Marshmallow Moderator Aug 15, 2019
    Horsault, Aug 15, 2019 :
    OP3 was released 3 years ago. Batteries are aging and as all chemical products can become instable.
    Anyway, even if there are securities and it's normal harmless, you should try to use fast charge as intended, that is, plug your device for ~30 minutes when battery is around 50%.
    otto2 likes this.
  3. Malg220 Honeycomb Aug 15, 2019
    Malg220, Aug 15, 2019 :
    Send us a photo :eek::eek::eek:
    Starcommander likes this.
  4. claudiumarius Froyo Aug 15, 2019
  5. Malg220 Honeycomb Aug 15, 2019
    otto2 likes this.
  6. claudiumarius Froyo Aug 15, 2019
  7. Starcommander Jelly Bean Aug 15, 2019
    Starcommander, Aug 15, 2019 :
    Thats the reason havoc os introduced smart battery charging. Ehat it basically does is to restrict the charging after 80% which saves the battery longevity also prevents burnin while charging over night
  8. claudiumarius Froyo Aug 15, 2019
    So, the battery was the problem? I can use the old charger?
  9. Starcommander Jelly Bean Aug 15, 2019
    Do one thing
    Dial *#800# and do the fast charger test.
    First do it with normal charger then do with your old charger, if the values are same you can use it.
    I also had oneplus 3 and then shifted to oneplus 6t. However I noticed that the new charger has bigger range of voltage inputs than the older one. So I use my new charger only. However, the old charger is used for other devices like bullets wireless and so on. But I suggest you to use the charger that is provided with oneplus 7 only
    Malg220 and DD6000 like this.
  10. claudiumarius Froyo Aug 15, 2019
    Starcommander
    Do one thing
    I also had oneplus 3 and then shifted to oneplus 6t. However I noticed that the new charger has bigger range of voltage inputs than the older one. So I use my new charger only. However, the old charger is used for other devices like bullets wireless and so on. But I suggest you to use the charger that is provided with oneplus 7 only​
    I did it with Ampere app, the results was the same. O should buy a better adapt
  11. Starcommander Jelly Bean Aug 15, 2019
    If same you can use, but when you have a new adapter why to use the older one.
  12. claudiumarius Froyo Aug 15, 2019
    The new one is for uk, all adapters are so bad...
  13. Starcommander Jelly Bean Aug 15, 2019
  14. anupritaisno1 KitKat Aug 15, 2019
  15. claudiumarius Froyo Aug 15, 2019
    anupritaisno1
    Everything seems to be intact here
    Where's the burn​
    Burn mean short circuit, is gone
  16. anupritaisno1 KitKat Aug 15, 2019
    anupritaisno1, Aug 15, 2019 :
    How do you know it's a short circuit?
  17. claudiumarius Froyo Aug 15, 2019
  18. anupritaisno1 KitKat Aug 15, 2019
  19. Horsault Marshmallow Moderator Aug 15, 2019
    Question is: why do you buy UK charger if you don't live in a UK plug zone?
  20. claudiumarius Froyo Aug 15, 2019
