Cable to connect to PC is very low quality via OnePlus 8T
  1. mauro_zz
    Eclair Feb 27, 2021
    mauro_zz , via OnePlus 8T , Feb 27, 2021 :
    Hi all, after struggling to connect my brand new phone to the PC I realized the cable in the box has a very low quality... My issue only?
    Tks
    Mauro
  2. Cervantes
    Moderator Moderator Feb 27, 2021
    Cervantes , Feb 27, 2021 :
    Hi
    I do not understand why it is of low quality: it is a fast charging cable
    what problem do you have to connect the phone to the computer
    Caomhin and Tokolozi like this.
  3. StefanStark
    Ice Cream Sandwich Feb 27, 2021
    Tokolozi likes this.
  4. #4
  5. mauro_zz
    Eclair Mar 1, 2021
  6. homelybore
    Froyo Mar 2, 2021
    homelybore , via OnePlus 8T , Mar 2, 2021 :
    Can you post a pic of the pc cable you are referring to?
  7. pablofg1978
    Head Moderator Head Moderator Mar 2, 2021
    pablofg1978 , Mar 2, 2021 :
    If you are referring to a thin and short cable, that is the headphones charging cable and it doesn't work for data transfer.
    You need to use the same cable that you use with the warp charger
    Caomhin, mauro_zz, Evgenij_ and 2 others like this.
  8. mauro_zz
    Eclair Mar 15, 2021
    mauro_zz , via OnePlus 8T , Mar 15, 2021 :
    Shame on me, that's exactly my mistake... Thanks a lot
    pablofg1978 likes this.
