153
Caches Explained
  1. anupritaisno1
    KitKat Oct 12, 2020
    anupritaisno1 , Oct 12, 2020 :
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    Also, get your terms right
    /cache is a mount point. cache is a partition label
    You can NOT say /cache partition. There is no such thing. A mount point can NOT be a partition. The "/" makes a very big difference in meaning
    You can say the partition that is mounted on /cache
    #61
    Artemus. likes this.
  2. PhotonBeard
    Cupcake Oct 17, 2020 at 12:55 PM
    PhotonBeard , Oct 17, 2020 at 12:55 PM :
    So is the answer absolutely nothing happens? Your post mentioned ART caches being rebuilt, but my understanding is that not even that is done.
    For example I wiped the Cache in OnePlus recovery and then ran a report of all files that had been modified that day (assuming that it would cause some files to be deleted and recreated). All I could see were log files, app databases, journal files etc. Nothing cache like.
    I then wiped the cache in TWRP and immediately could see that the contents of /data/dalvic-cache had been rebuilt.
    #62
