9
Call Audio low
  1. Ranju_Varughese Cupcake Feb 1, 2018
    Ranju_Varughese, Feb 1, 2018 :
    After updating my oneplus 3 to oreo, the call audio has drastically reduced. It is very difficult to hear what the other person is speaking. Please fix this bug.
  2. G_Sam_S_YGlb Cupcake Dec 9, 2018
  3. ilquilli Donut Dec 9, 2018
    H1544436213073 and G_Sam_S_YGlb like this.
  4. Mathew Vadakedom Cupcake Dec 9, 2018
  5. F_Kazey_Kash_mTHW Cupcake Dec 10, 2018
  6. H1544436213073 Donut Dec 10, 2018
  7. H1533481376523 Cupcake Dec 10, 2018
    G_Sam_S_YGlb and H1544436213073 like this.
  8. ilquilli Donut Dec 10, 2018
    ilquilli, Dec 10, 2018 :
    i think it's impossible to keep a situation like this. why one plus has still not do anything?
  9. G_Christo_Kulangara_euaj Eclair Dec 10, 2018
  10. neihguk Cupcake Dec 11, 2018
    neihguk, Dec 11, 2018 :
    Its probably because of dust being accumulated on the ear piece grill overtime. Try cleaning the grill. It worked for me.
    G_Sam_S_YGlb and j8765 like this.
  11. ilquilli Donut Dec 11, 2018
  12. satish7937 Gingerbread Dec 11, 2018
    satish7937, Dec 11, 2018 :
    Its a hardware issue. The earpiece sounds low, due to accumulation of dust and moisture.
    I went to Service centre, they charged me ₹ 470/- for cleaning. It fixed the issue.
  13. G_dima_shuster_KXCt Eclair Dec 11, 2018
  14. B1544585077795 Cupcake Dec 12, 2018
    H1544436213073 likes this.
  15. H1544436213073 Donut Dec 22, 2018
    H1544436213073, Dec 22, 2018 :
    how you did that?
    can you explain me the procedure?
    G_Sam_S_YGlb and ilquilli like this.
  16. ilquilli Donut Jan 9, 2019
    ilquilli, Jan 9, 2019 :
    i didn't believe it...using a tootgbrush over the speaker has made it works again!!! i finally can use again my oneplus 3t
    G_Sam_S_YGlb likes this.
  17. dcuatro Donut Jan 9, 2019
    dcuatro, Jan 9, 2019 :
    Same here. Nor the toothbrush trick nor a cache wipe nor a factory reset solved the problem. The technical assistant kindly offered me to ask for a RMA, which is fine, but since it's a very common topic on this forum by bet it's not a hardware, but a software related problem. For example, WhatsApp audio calls sound louder.
    Nakele and G_Sam_S_YGlb like this.
  18. G_Rasmus_Nielsen_DFbV Cupcake Jan 9, 2019
    ofh and G_Sam_S_YGlb like this.
  19. Murray121 Cupcake Jan 10, 2019
    Murray121, Jan 10, 2019 :
    I had a similar issue, funnily enough straight after cleaning my screen.
    Cleaning the speaker grill with a toothbrush didn't seem to work. So I got the sim card removal tool and gently scraped the speaker grill clean. The call volume increased dramatically. I promise you, its just dust and grime build up.
  20. N1545510851702 Cupcake Jan 11, 2019
