2
call audio not heard
  1. Vineeth_Kumar_V_V
    Eclair Sep 6, 2019
    Karan9559 and X1558107433724 like this.
  2. X1558107433724
    Cupcake Sep 6, 2019
    X1558107433724 , Sep 6, 2019 :
    I have a similar issue when contacting Samsung Galaxy 10s that has been going on since the phone was released.
    I have cleared the cache, reset settings, and replaced the sim card.
    OnePlus told me in July it is a known issue, but there is no known resolution or solution being developed per their help desks knowledge. I called in today and received the same response.
  3. sushanth_goud
    Eclair Sep 10, 2019
    sushanth_goud , Sep 10, 2019 :
    >Try to switch off your mobile then remove your sim and re-insert it and check.
    >>If issue continues then try to Swap your sim cards from Sim slot 1 to Sim slot 2 and vice versa and check.
    >>>If still having same issue then check if you are having same issue by inserting another Sim on your device. If another Sim is working fine then it might be a Sim Card issue and you can replace it.
  4. X1558107433724
    Cupcake Sep 11, 2019
    X1558107433724 , Sep 11, 2019 :
    I have tried each of those options and replaced the sim, but they did not improve the problem.
    thank you for the recommendations.
  5. sushanth_goud
    Eclair Sep 11, 2019
  6. Vineeth_Kumar_V_V
    Eclair Sep 14, 2019
  7. sushanth_goud
    Eclair Sep 15, 2019
