[Submitted] Call drop after 1 or 2 minutes
  1. pratyush.vaidya
    Cupcake Aug 26, 2020
    pratyush.vaidya , Aug 26, 2020 :
    I bought the One plus nord from Amazon and since it's start the device is causing call drop after every 1 or 2 minutes in most of the calls. Really not expected from a top brand smartphone
  2. Keyur2030
    Donut Aug 27, 2020
    Keyur2030 , Aug 27, 2020 :
    Thanks for the feedback. We need more information from you. I pinged you in private chat. can you please check & update. Thanks
  3. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member Aug 27, 2020
    Ghazala.Yasmeen , Aug 27, 2020 :
    For analyzing this better we would need more details to get this sorted out at the earliest. We have dropped you a personal message and would request you to respond the same.
    Regards,
    Ghazala
  4. gokul3krish
    Cupcake Sep 15, 2020
    gokul3krish , via OnePlus Nord , Sep 15, 2020 :
    If wifi calling option is turned on in your device try turning it off and check if the call drop issue continues.
    You need to go
    settings>wifi& network>sim&network>sim setting>sim1/sim2>enhanced communication> wifi calling
