call drop/ auto disconnect
  1. Ashraf.rony
    Cupcake Jul 10, 2020
    Ashraf.rony , Jul 10, 2020 :
    I'm having call drop /auto disconnect issue while calling since the last/latest op6 update. anyone else have the same issue? please help.
  2. drl431
    Marshmallow Jul 10, 2020
    drl431 , Jul 10, 2020 :
    Try removing and reseating the sim tray to ensure good contact with the sim card (with power off).
    Caomhin likes this.
  3. Ashraf.rony
    drl431
    Try removing and reseating the sim tray to ensure good contact with the sim card (with power off).​
    done already. SIMs are working fine on other devices. but not on my op6. in addition, sim detection and no network problem occurred few times.
  4. drl431
    I have not had an update affect calling or receiving calls on my OP6. You might check with your carrier/network provider.
    Caomhin likes this.
  5. Ashraf.rony
    As those SIMs are working fine on another device, that should not be a network problem. I've tried using my dad's SIM, same problem happened in my phone. Can't be sure if it is hardware or software. [e]1f61e[/e]
    thank you for replies.
  6. drl431
    Assuming the issue is with regular cell calls, and not wifi calling, the other option to consider is a factory reset.
    Caomhin likes this.
  7. Ejthenextmj
    Donut Jul 11, 2020
    Ejthenextmj , Jul 11, 2020 :
    Greetings I have some kind of issues sometimes im unable to make calls but when people anwser they cant hear me any ideas. An still were i live the 4g network on my one plus 8 pro is just .086MBPS compare to the last phone that was 100.45 MBPS so something needs to get fix with the one plus 8 pro i guess??
    Ashraf.rony likes this.
  8. Westenke
    Cupcake Jul 11, 2020
    Westenke , Jul 11, 2020 :
    One more with the same problem on the OP6. I have tried: ´
    • Factory reset with all wypes datas, no improvements.
    • Use diferents conectivities (2G/3G/4G), no improvements.
    • My SIM card work on other phones, but others SIM cards doesn't work on my OP6
    All this come from the last update 10.3.4.
    I cant downgrade to an older version form setings, so I call the service to repair
  9. Ejthenextmj
    Donut Jul 11, 2020
    I think this need a fix on the software or their antenna on the one plus 8 pro signal something needs to be causing the problem
  10. Caomhin
    Lollipop Jul 12, 2020
    Caomhin , via OnePlus 6T , Jul 12, 2020 :
    Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    Ashraf.rony and Westenke like this.
  11. Ashraf.rony
    Cupcake Jul 20, 2020
    Ashraf.rony , Jul 20, 2020 :
    done. problem not solved. my phone can't find the mobile network. tried switching to 3G/2G.didn't work either. but same SIM working on other phone properly.
