57
Call drop issues on One Plus 6 Handsets in India (Urgent)***
  1. KOGDENCOL1
    Cupcake May 29, 2018
    KOGDENCOL1 , May 29, 2018 :
    I had a few drop calls, Do the Oneplus 6 have a setting for giving a sound alert when the call is dropped? I keep talking for a minute before realizing the call was dropped. On T-Mobile USA here.
  2. sabbyjay
    Honeycomb May 30, 2018
    sabbyjay , May 30, 2018 :
    We are basically beta testers. This is what happens to OnePlus early adopters.
  3. otto2
    Photography Expert May 30, 2018
    otto2 , May 30, 2018 :
    Tell this Samsung users, whose Oreo Update ended up in boot loops so users had to visit service center, tell this Apple users whose updates ended in a hard brick , so they had to visit service center...... If you re the greatest, perfect coder feel free to write your own, "perfect" software.
  4. sabbyjay
    sure let's compete with the companies that are know for software issues.
    Also, there's nothing here to get all worked up about.
  5. H1527325581761
    Cupcake May 30, 2018
    H1527325581761 , May 30, 2018 :
    Same here. Incoming calls inaudible from caller's end. Call drops after 5-6 secs of being inaudible. Happens in 2nd SIM (Airtel). What's wrong OnePlus ??
  6. kumaryashwin
    Jelly Bean May 30, 2018
  7. meatandy
    Oreo May 30, 2018
    meatandy , May 30, 2018 :
    I had one call here in the states where the call suddenly went dead for a second or two and then immediately reconnected also on T-Mobile network.
    I wasn't sure if it was poor signal but also the weather was bad in my area at the time.
    sand0r likes this.
  8. izzykasha
    Lollipop May 30, 2018
    izzykasha , May 30, 2018 :
    I blame global warming and solar flares.
    plus the curry I had last night
    abhinavsunny1 and meatandy like this.
  9. I1527696871968
  10. kiran.satya999
    Gingerbread May 30, 2018
    kiran.satya999 , May 30, 2018 :
    Even I've the same issue, when called for help Amazon team verified my device through smart check and told device is fine
    But I'm still facing call drops
  11. I1527696871968
  12. Ashura6666
    Eclair May 30, 2018
    Ashura6666 , May 30, 2018 :
    Yes me too. Also why is there no option to let the call remain in the pop window even after answering. It always go to fullscreen app instead of just a pop up. It is super annoying when playing games or doing some other work on the phone. It was a feature from Android marshmellow and op has simply removed it?
  13. ajay_s001
    ajay_s001 , May 30, 2018 :
    Hi, facing severe call drop issues on my OP6. It cannot be a signal problem as I haven't faced this issue till date with any of the previous phones I used. Haven't changed locations or providers either.
    Hope it is a software issue and a fix will be issued soon without which this is a disaster. This is the basic thing for a phone!!!
  14. Joby Varghese
    Eclair Jun 2, 2018
    Joby Varghese , Jun 2, 2018 :
    Same here.I am using Idea as primary and bsnl as secondary.Please make a patch as soon as earlier
  15. prvvn
    Cupcake Jun 2, 2018
  16. Terryruiz
    Ice Cream Sandwich Jun 2, 2018
  17. Terryruiz
    Terryruiz , Jun 2, 2018 :
    NEWS
    OnePlus admits there’s a OnePlus 6 bug that silences phone audio
    BY C. SCOTT BROWN
    A OnePlus 6 bug causes phone audio to go silent, with placing the call again the only workaround.
    OnePlus admitted to this bug, and will fix it in an upcoming OTA.
    However, the company did not specify when this OTA would launch.
    The OnePlus 6 is one of the most talked-about phones of the year, but the launch of the device hasn’t been without problems. To add to those issues, OnePlus now admits that there is a OnePlus 6 bug that silences phone audio during a call.
    OnePlus promises that the bug will be fixed in an upcoming OTA rollout, via Fuse Boxed, but doesn’t give any indication as to when that update may launch
    The OnePlus 6 bug is easy to duplicate yourself if you happen to have the latest flagship. To do so, during a phone call, switch the phone into speakerphone mode. Instead of speakerphone mode activating, the call instead falls silent. If you try to switch back to handset mode, there’s still no audio.
    The only way to get audio back is to hang up on the call and then reconnect.
    Along with fixing this very inconvenient bug, the next OnePlus 6 update will also restore the status bar battery percentage display option. According to Fuse Boxed, here is the complete list of fixes and updates coming soon:
    Display more notification icons in the status bar, when reducing the display size setting has created more space before the notch
    Removal of the three overflow status bar dots on all devices
    Increased notification and ringtone sound volume
    Rear camera autofocus improvements
    Fix problems when using Indian carrier IDEA as secondary/non-data sim
    Fix silent phone calls bug
    Restore status bar battery percentage option
    Add scheduled do-not-disturb feature
    One of the bugs that won’t be fixed in the upcoming OTA is one where the screen ratio is off when viewing certain apps. OnePlus admits that a fix for this problem is coming “post OTA”
    vidz and U1527998086096 like this.
  18. sdesai264
    Eclair Jun 2, 2018
    sdesai264 , Jun 2, 2018 :
    No response from One Plus Technical support inspite of so many who confirmed the issue ...
    #38
  19. elanglois
    Lollipop Jun 2, 2018
    elanglois , Jun 2, 2018 :
    Really? Is there an echo in the forums?
    #39
  20. chaitanyakhaitan
    Honeycomb Jun 2, 2018
    chaitanyakhaitan , Jun 2, 2018 :
    Guys, is anyone facing the issue where in status bar is showing mobile signal, but actually there is no cellular network.
    If someone calls, it's saying switched off and you need to reboot device for it to work again.
    Thanks
    #40
