57
Call drop issues on One Plus 6 Handsets in India (Urgent)***
  1. chaitanyakhaitan
    Honeycomb Jun 4, 2018
    chaitanyakhaitan , Jun 4, 2018 :
    Which model are you using?
  2. Prash05
    Cupcake Jun 5, 2018
    Prash05 , Jun 5, 2018 :
    I was having jio in my 1st slot and bsnl in 2d,during peak hours person calling on my bsnl number couldn't hear me at all did factory ,network reset,cleared catch with no results switched the SIMs jio started having the same issue ,called amazon technical team and they tested the phone remotly and said signal on sim 2 failed and she said it was a hardware issue and raised a request for replacment its on the way...so what we are thinking as software bug might be an hardware thing so call the amazon technical team and get it checked...
  3. F_Srinivasa_Velagala_sQR
    Froyo Jun 5, 2018
    F_Srinivasa_Velagala_sQR , Jun 5, 2018 :
    which app did you install for testing.
  4. Y1527151126111
    Froyo Jun 5, 2018
    Y1527151126111 , Jun 5, 2018 :
    blannco diagnostics
  5. F_Srinivasa_Velagala_sQR
    Froyo Jun 5, 2018
  6. Prash05
    Cupcake Jun 5, 2018
  7. Y1527151126111
    Froyo Jun 5, 2018
    given by amazon technical team
  8. NovinDavis
    KitKat Jun 5, 2018
    NovinDavis , Jun 5, 2018 :
    n
    We get it .. you don't have to post it 5 times
  9. ullasn
    Froyo Jun 5, 2018
  10. sahilangz
    Eclair Jun 5, 2018
    sahilangz , Jun 5, 2018 :
    Yes facing it badly .From past two days my Sim card is not working suddenly , which worked fine in other devices . Sometimes there are signals but the calls still cannot be made and network also . it recognises the sim but it shows emergency calls only . The other sim are also not working on my device . same problem . oneplus look into this problem as soon as possible .
    chaitanyakhaitan and ullasn like this.
  11. ullasn
    Froyo Jun 5, 2018
    ullasn , Jun 5, 2018 :
    ss
  12. sahilangz
    Eclair Jun 5, 2018
  13. Chaks_IN
    Gingerbread Jun 5, 2018
    Chaks_IN , Jun 5, 2018 :
    I use Jio and Vodafone and I haven't had any issues particular to OP6. I have been facing call drops and cross talks ever since Aircel closed and people started migrating to other networks. OP has officially acknowledged issues with Idea I think.
  14. ullasn
    Froyo Jun 5, 2018
  15. ullasn
    Froyo Jun 5, 2018
    if I click on a no. to call it's gets hanged and make call after 10secinds
  16. Joby Varghese
    Eclair Jun 5, 2018
    Joby Varghese , Jun 5, 2018 :
    Yes.they admitted Idea users facing issue
  17. Y1527151126111
    Froyo Jun 5, 2018
    They admitted to a situation of dual sim n which idea is used for data
  18. chaitanyakhaitan
    Honeycomb Jun 5, 2018
    chaitanyakhaitan , Jun 5, 2018 :
    Which one plus 6 variant are you using?
  19. Chaks_IN
    8GB/128GB
  20. chaitanyakhaitan
