Working call drop
  1. L1534156180926
    Cupcake Aug 14, 2018
  2. BobbyV8_
    The Showcase Reviewer Aug 15, 2018
    BobbyV8_ , Aug 15, 2018 :
    It's probably your network issue.
    If you still want to try fixing it on your side, Network reset & reboot. Switching on flight mode and turning it off can help to some extent.
  3. AbhisekMandal
    Donut Sep 13, 2018
    AbhisekMandal , Sep 13, 2018 :
    for me, calls are getting dropped when talking thru earpiece.
    calls working fine when using speaker mode.
    is it the same for you?
    using single sim: Airtel 4G
    oxygen OS 5.1.11
    pretty sure it's a device issue and not a network issue
  4. BobbyV8_
    The Showcase Reviewer Sep 14, 2018
    BobbyV8_ , Sep 14, 2018 :
    Did you try this?
    If this doesn't work, Backup data, Factory reset.
    Kindly use reply option.
