94
Call of Duty Mobile - Game crashing/screen flicker only in battle royale.
  1. jstiggie
    Honeycomb Oct 31, 2019
    jstiggie , Oct 31, 2019 :
    I now play on low graphic seetings on COD without issues. It seems to be the higher graphic settings.
  2. jstiggie
    As if other phones are completely bug free. They'll fix it, but statements like yours don't help the bug fixing.
  3. goodwind
    Cupcake Oct 31, 2019
    goodwind , Oct 31, 2019 :
    In my case game just crashes when I play BR on low graphics settings and flickers when on medium or high. Frequency of occurrence is the same
    jstiggie likes this.
  4. jstiggie
    Then im lucky I guess. I play atm on low graphics and medium frames and it works so far.
  5. S7arting_1725
    S7arting_1725 , Oct 31, 2019 :
    Anche io ho questo problema. Cioè che solo in Battle Royale il gioco e un certo punto si blocca e devozione per forza chiudere l'applicazione e rientrare perché funzioni di nuovo
    codemasters likes this.
  6. karthik463
    karthik463 , Oct 31, 2019 :
    It is very clear the issue is related to the OS itself. All my friends owning a mobile with 10 reports the same problem
    1: Game Flickers in middle on any settings
    solution: Quit and re-join session(hope player is not killed)
    2: Game Flickers and hangs when scope is put into use.
    solution is same as above
    3: Sudden black screen but player is still connected
    This is very much visible on any settings
    If One plus is listening, show some light
  7. Rykoux
    Cupcake Nov 1, 2019
  8. ligas
    Cupcake Nov 1, 2019
    ligas , via OnePlus 7 Pro , Nov 1, 2019 :
    For my case the solution is to leave the optical lens of any machine gun. It wreeze if you use sniper or optics. If you shot without anything luckily you have no issue.. Try.. As soon as you take it go to the bag and leave it for both weapons.
  9. rbelde
    Cupcake Nov 1, 2019
    rbelde , Nov 1, 2019 :
    Somebody needs to fix this thing! Is so annoying when someone kill you because of this problem!
  10. E1572362467873
    Cupcake Nov 2, 2019
    E1572362467873 , via OnePlus 7 , Nov 2, 2019 :
    According to the reports and complaints submitted on Google links , the majority of people suffering the similar issues are OnePlus users no matter what device they using but it is also experienced by other Samsung users and other devices , making it a game bug as per my conclusion..
    jstiggie and Prabhu Narayanasamy like this.
  11. zTheReaperX5
    Cupcake Nov 2, 2019
  12. jaitzz
    Eclair Nov 2, 2019
    jaitzz , Nov 2, 2019 :
    I did share the bug, but I didn't get a solution yet.
  13. DmitryDV
    Cupcake Nov 3, 2019
  14. kKoI1233
    Gingerbread Nov 3, 2019
    kKoI1233 , Nov 3, 2019 :
    (for CODM)
    I first saw this issue on the 7T (OOS 10.0.x)
    Followed by the 7 and 7 pro that moved to OOS 10.0.x (and only occurred on 10.0.x, 9.x.x is bug free)
    Now i hear the 6T has it too, on OOS 10
    From this we can tell:
    1. It's not tied to device aspect ratios
    2. It's not device specific
    3. It seems to only occur on android 10
    4. It only happens in Battle Royale
    Though whether the issue is caused by CODM by being incompatible in some way with Android 10 or by the rushed OOS 10.0.x based on Android 10 is unclear...
    Best to file bug reports with OnePlus as well as the CODM devs.
    jstiggie and Starcommander like this.
  15. Starcommander likes this.
  16. DmitryDV
    Cupcake Nov 3, 2019
    DmitryDV , Nov 3, 2019 :
    Seems to me, problem is solved on server side. Everything is running just fine during last hours.
  17. Ashuwani24
    Cupcake Nov 3, 2019
  18. Ashuwani24
    Cupcake Nov 3, 2019
    Ashuwani24 , via OnePlus 7T , Nov 3, 2019 :
    same issue here
  19. chatterjee8
    Cupcake Nov 3, 2019
    chatterjee8 , Nov 3, 2019 :
    Hello guys, try optimizing the battery setting for the game, it worked for me.
  20. BeNKazaV
    Cupcake Nov 3, 2019
    BeNKazaV , Nov 3, 2019 :
    Same issue, OnePlus 7Pro.
    At first, I thought it was because the phone is warming but it's not, if it was because of this it will crash also in an MP match but it's not.
    Anyway, for example, I play 1 game on full brightness and it crashes so I thought ok the phone is too warm so I played in a dark room with lowest brightness (also tried with battery saver) and it still happens even tho the phone is not warming.
    When the game crash I can still move ingame but the screen is still flickering, So when it crashes I try to find a place to hide and then lay on the ground, closing the game and relog, then continue playing.
    So if the problem is because the warmup (which is not even so warm) I shouldn't even be able to continue to play.
    I hope someone will fix it, also reported about this bug in-game.
    KNS5 likes this.
