U1577033011718 , via OnePlus 6T , Oct 3, 2021 : After updating the android 11 is I can't play my call of duty mobile game so plz fix this issue
U1577033011718 , via OnePlus 6T , Oct 3, 2021 : It's not a mobile problem . I think the os 11 update is problem . That's y call of duty mobile app is not working.
U1577033011718 , via OnePlus 6T , Oct 8, 2021 : Yes I am sure about that becoz many facing this issue after os 11 update
SaummaySinghal , via OnePlus 6T , Oct 14, 2021 : Facing the same issue after updating to Android 11. Moreover the update never notified that it'd be updating the OS to 11. It just mentioned these are security patch updates.
SaummaySinghal , via OnePlus 6T , Oct 14, 2021 : Makes sense but the user's prolly not gonna look at the number code and try to figure what the update is for right? The Update details never mentioned it'd be an OS 11 update.
Artemus , Oct 14, 2021 : That's because it's the next version update for OOS 11, of course it's not gonna mention it.
SaummaySinghal , via OnePlus 6T , Oct 14, 2021 : Oh no I wasn't running OS 11 before the recent update I got. Well, I don't wanna get into a chain of arguments here, a lot of us are kinda affected by this new update wherein we can't access a few apps properly, WhatsApp Messenger is unable to download/access any media to/from the device and Call of Duty has this weird error as mentioned in the post. I wish there could be a solution for these problems maybe an update that could Fix this bug.
W1552595955446 , via OnePlus 8T , Oct 14, 2021 : Factory reset had the same issue on my 6t I used to own and that solved it.
SaummaySinghal , via OnePlus 6T , Oct 14, 2021 : Does that mean I cannot run Android 11 (even when provided by OnePlus) on my device and the only way to continue to use my apps normally would be to trace back to the factory version ?
W1552595955446 , via OnePlus 8T , Oct 14, 2021 : If you factory reset it will still be Android 11 but it'll give it a clean slate
SaummaySinghal , via OnePlus 6T , Oct 19, 2021 : Makes sense, any tips on how to keep all my data safe while doing so?
W1552595955446 , via OnePlus 8T , Oct 19, 2021 : So personally I don't backup my data but that's just me. Wait except my contacts that backs up to my email and I restore them when I enter my email when setting up my phone. I would advise you to look through apps on the Google Play store to back up your data.
