Call receiving option not working
  1. vivekkharwar Cupcake Nov 7, 2018
    vivekkharwar, Nov 7, 2018 :
    Hi Guys,
    After updating recently my call receiving option is not working. Is this the problem with my phone or it's software update problem?
    x
  2. ngydat KitKat Nov 7, 2018
    ngydat, Nov 7, 2018 :
    What do you mean by that ? The screen doesn't turn on when you have a call, is that what you mean ?
  3. vivekkharwar Cupcake Nov 7, 2018
    Whenever someone calls me I am unable to swap that round button up to receive the call.
  4. ngydat KitKat Nov 7, 2018
    Do you actually see the round button ?
  5. vivekkharwar Cupcake Nov 7, 2018
    yes I do. it does appears on the screen. just that the touch doesn't work when the call comes in
  6. ngydat KitKat Nov 7, 2018
    Ok. I thought at first your problem was a little different : if it was like the one I had in mind, I could have suggested you a solution. But in this case, I'm afraid I can't help you on this one.
  7. X1528536716073 Cupcake Nov 8, 2018
    X1528536716073, Nov 8, 2018 :
    Facing the same problem in One plus 6. The incoming number is not displayed on the screen. It only rings. Neither the No. nor the icon to attend the call is displayed. The problem is not resolved even after upgrading the new version 2018.11. Can anybody help in this regard? Thanks.
  8. G1538283146135 Cupcake Nov 8, 2018
    G1538283146135, Nov 8, 2018 :
    I was facing this issue earlier...after update the call is displayed on the screen but not able to receive..pls help
  9. B_Wrath Marshmallow Nov 8, 2018
    B_Wrath, Nov 8, 2018 :
    Your problem is different from the OP.... You both do this...
  10. X1528536716073 Cupcake Nov 8, 2018
  11. vivekkharwar Cupcake Nov 8, 2018
  12. X1528536716073 Cupcake Nov 8, 2018
  13. R1541440256115 Cupcake Nov 8, 2018
  14. Q1541656022459 Cupcake Nov 8, 2018
    Q1541656022459, Nov 8, 2018 :
    I cannot see incoming calls on my screen, just can hear the ringtone. Have a solution for it?
  15. ngydat KitKat Nov 8, 2018
    ngydat, Nov 8, 2018 :
    Long-press on the phone app -> select "App info" -> Notifications -> INcoming calls (tap on the text not the checkbox) -> Behaviour -> Select "Make sound and pop up on screen"
    Q1541656022459 likes this.
  16. G1538283146135 Cupcake Nov 8, 2018
    this is not working
  17. B_Wrath Marshmallow Nov 8, 2018
    Did you follow the steps completely???
  18. ngydat KitKat Nov 8, 2018
    His problem is a little different : from his posts above, it appears that when someone calls him, the screen DOES turn on but the touchscreen doesn't respond so he can't answer the call.
    Edit : my bad. Since the thread starter and the one you were replying to have a similar nickname, I thought at first it was the same person. So, discard my post.
  19. G1538283146135 Cupcake Nov 8, 2018
    even I am facing the same issue and even when I do voice call in whatsapp the screen didn't not turns off till call doesn't get disconnected. I can't even disconnect it by my self.
  20. G1538283146135 Cupcake Nov 8, 2018
    I am facing these kinds of issue after pie update . pls help.
    A1541664929998 likes this.
